HD audio device soundmax -a driver problem
  1. Posts : 8
    win 7 ultimate 64Bits
    Hi Guys,
    I recently installed the SupremeFX X-Fi Audio Card that came with my ASUS Maximus II Formula. It worked previously on my 2.1 desktop speaker for a while but just few days ago I got issue with soundMax. I tried unistalled and reinstalled the software from DVD that came with it but problem with the "HD audio device soundmax -a driver problem" persist. I am stuck! Thank you in advance.
  2. Posts : 6,879
    Win 7 Ultimate x64
    id102, welcome to the forums.
    I wouldn't use the disk that came with the motherboard, doubt it even has Windows 7 drivers on it, Instead use the one from Asus for it,
    ASUSTeK Computer Inc. - Motherboards - ASUS Maximus II Formula
    And if you want the X-Fi software for it as well they have an update version, look under Utilities to find it.
  3. Posts : 8
    Thank you for reply.
    I've downloaded all relevant Drivers for ASUS Maximus II Formula from ASUSTek Computer Inc as you suggested. In Utilities I installed "AsusUpdt_V71706", Installed the latest "soundMAXAD1988B_Adio_V610X6585_Win7", and lastly installed "SB_XFi_V10_R19_XpVistaWin7" and updated it. After restarting windows I am still having issue with it. Will that help if I reinstall win7 and start all over again this mean I have to reset my RAID ARRAY again but I fear that I may get the repeated problem...Is there any other way around this problem.Thanks again
  4. Posts : 8
  5. Posts : 8
    I 've upload some images for your reference.
