Windows 7: [Sound crackling ] VPN client messed up my sound settings
06 Jun 2010   #11
Windows 7 Profesional x86, Mac OS X 10.6 Snow Leopard
Well done on finding a solution I'll mark this thread solved as soon Bishooni reports back.
06 Jun 2010   #12
Windows Seven Ultimate 32bits
Too bad ! I just finished reinstalling my OS, that problem has drained every bit of patience I had. But oh well, I'm sure that'll prove useful to some other people. And many thanks to altamash and everyone else who helped btw.
Anyhow, everything is fine now, I needed a fresh start anyways. So yeah, solved !
07 Jun 2010   #13
Quote   Quote: Originally Posted by altamash View Post
Finally found a solution. I installed Packetix again and this time it did not ask me about the audio/video optimization. Next i ran packetix and here is what i did:
Click tools > Optimization for Windows Vista
It should open a dialog box saying that optimization for windows vista is already done/present and will ask you if you want to remove it. The remove text is misspelled as remote (it will read as 'do you want remote optimization'). I clicked yes and my speaker icon in taskbar changed to 'removed' status and when i put my mouse cursor on it, it said 'sound system not available' or something. It returned back to normal soon followed by a confirmation from packetix client that optimization was removed.
I ran my 720p mkv movie that i had problems with and now its running fine. I hope this helps those of you facing similar problem. Glad i found an easy fix. I'll proceed with uninstalling packetix again as their speed is slow anyways comparing other free vpns.
Also i want to thank Bishooni for bringing the attention to the audio/video optimization. Seriously i had almost given up till i found your thread. I hope this fixes the problem for you aswell.
Hello Everyone,
I have the same problem. Packetix optimization for vista screwed my audio. I tried removing the optimization as stated previously but the glitch still exists.
Do I need to uninstall/reinstall or something? Please help.
10 Jun 2010   #14
after removing the optimizations, if the glitch still exits, try uninstalling and reinstalling your audio drivers. Although simply removing the optimization from packetix did the trick for me
07 Jul 2010   #15
Min Naing
I've the same problem too. I've tried altamash's solution. But the noise still annoying me.
08 Jun 2011   #16
Windows 7 Ultimate x86
For guys still have the problem,you may run the vpn client as administrator and try altamash's solution again.I think the problem should be solved.^^
24 Oct 2011   #17
Great, I got it today
I resolved this hately problem today:
1. Run the PacketiX as system administrator(right key click on the software link or file)
2. Tools->Optimization for windows vista...
3. Remove it, may be there is a wrong word(revote), go on and wait for the successful notice, and try your player again, does it work well?
Search this Thread:
Advanced Search
Crackling sound and System lag
Hi everyone. I am posting this as last resort. Recently i upgraded from Windows XP to Windows 7 Ultimate edition and got a problem i ve seen for the 1st time in my life. Problem was Crackling sound that sounds like some kind of static electricity that is mixing with normal sounds. I ve...
Sound crackling/popping
Hello! I have had this problem for quite a long time but I am getting enough from it. Basicly nearly always when I start playing any sound source there is crackling in sound at begining. Happens usually with high frequenzy sounds, adjusting volume on youtube videos or click rewinding youtube...
Crackling and distorted sound in Win 7
Hi all, A couple of weeks ago I bought and downloaded a copy of the "AOS system optimizer" and after using it to 'optimize' my system it instead screwed it up big time... now my sound crackles and stutters when I play all media, online or offline, dvds, youtube, games, etc... Technical...
Genius Sound Maker Value 5.1 Crackling Sound
Hello, I upgraded my Win XP to Win 7 like 1 month ago. Downloaded all drivers (from their sites) updated them... then i open WMP 11 and start playing some music. After listening to that i heard some weird sound lag, I believe its called crackling. I searched on internet found some solutions, but...
Crackling Sound
Hi all, Am new to the forums so please be patient with me! :D My machine is fairly old but runs Windows 7 32Bit perfectly fine. In fact I was amazed to find all the hardware is picked up fine and runs nearly as fast as XP did. Have been using it for some time without issues but recently...
Crackling and dragging sound
I have a Toshiba M45 S359 and upgrade to Windows 7 from XP and I get horrible crackling sound. Installed the latest realtek a97 drivers, but no avail. Anybody have a fix?
