Sound issues
  1. Posts : 9
    windows 7
    Sound issues
    I built a custom computer, and the sound doesnt seem right...And i just bought a little suround sound system and the sound sounds like crap, am i missing any drivers or something?
  2. Posts : 3,427
    Can you fill out your system specs please? Click User CP at the top and then click Edit System Specs. that will allow us to find drivers for you
  3. Posts : 9
    windows 7
    updated
  4. Posts : 3,427
    I'm really sorry about this... what's your motherboards model number? that will allow me to find the sound driver for you
    edit: never mind here you go: http://www.realtek.com/downloads/dow...&GetDown=false
  5. Posts : 9
    windows 7
    Which one do i download?
  6. Posts : 3,427
    Assuming your sound is Realtek HD (which is what you have put in your specs) download the one called Vista, Windows7 Driver(32/64 bits) Driver only (Executable file) that is an automatically installing one so its nice and easy, just run the exe
  7. Posts : 9
    windows 7
    Alright lemme see if this works.
  8. Posts : 9
    windows 7
    HAHAHA believe it or not, uninstalling the realtek hd audio fixed my problem.
  9. Posts : 3,427
    Just goes to show glad you got it sorted anyway
