Windows 7: Installed sound themes are OK; not so if I modify
08 Jun 2010   #1
I've been trying to change some of my sounds (Windows 7 HP machine) and found that they won't work.
If I change a theme, the installed sounds are OK.
If I try to change one of the sounds and replace it with one from a directory where I keep .wav files, they will not play.
I've tried re-naming the theme directory to something different; no luck.
I've even tried replacing the existing themed .wav file (located in the Windows/media directory) with one of my files but it denies me permissions.
Anyone have any idea what may be wrong?
Is there a "permission switch" I've overlooked?
Thanks!
Vilmar
Similar help and support threads for2: Installed sound themes are OK; not so if I modify
How To remove installed themes ...? Customization
Just installed windows 7, No sound Sound & Audio
Solved Installed Nvidia GT 430 = No Sound Sound & Audio
Sound themes, icon packs and gadgets! Customization
No sound, no sound device detected, drives installed? Sound & Audio
Sound scheme changed by Desktop Themes Themes and Styles
No sound with P5P 800, drivers installed Sound & Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
