| Windows 7: Sound Problem. |
11 Jun 2010
#1 | | Windows 7 Home Premum x32 Thundersly, Benfleet, Essex |
Sound Problem. I purchased a Tevion Turntable that runs using Audacity as its output. I am also using Skype. After plugging in and using the turntable I went back to use Skype to have a chat and got a very robotic sounding voice as my output which I was also assured was very distorted as well So I removed the turntable uninstalled Audacity Skype still made my voice very distorted. So I then removed Skype completely from my PC. I then used windows recorder to test again and my voice sounds to me like a speeded up version of Mickey Mouse. Has anyone any idea of what has caused this and how I can now get my voice to sound normal? | My System Specs |
| Computer type PC/Desktop System Manufacturer/Model Number Medion E6124 OS Windows 7 Home Premum x32 CPU M330 @ 2.13GHz 2.13GHz Motherboard MSI MS-7502 Memory 4 Gb Sound Card HDAudio\FUNC_01&VEN_10EC&DEV_0269&SUBS Monitor(s) Displays Generic pnp Monitor Screen Resolution 1024 X 768 Hard Drives Generic- Multi-Card USB Device Disk Drives
HL-DT-ST DVDRAM GT20N ATA Device DVD/CD-ROM Drive
ST9500325AS ATA Device Disk Drives Antivirus Zone Alarms Free Antivirus Browser IE 8 Other Info No other programs on the laptop at the moment. |
11 Jun 2010
#2 | | Windows 7 Home Premium (64-bit) *** Windows XP SP3 (32-bit), OSX 10.6 |
Hi Brian,
We'll need to know what kind of sound card you have. Please fill out your System Specs as completely as possible so we can better assist you.
Cheers,
Walker
Windows Outreach Team | My System Specs | | System Manufacturer/Model Number HP Pavilion dm3 (netbook) *** 27" iMac (Dual-Boot) OS Windows 7 Home Premium (64-bit) *** Windows XP SP3 (32-bit), OSX 10.6 CPU AMD Athlon Neo X2 1.6GHz *** Intel Core i7 Quad Core 2.8GHz Memory 4.00 GB *** 4.00 GB Graphics Card ATI Radeon HD 3200, 384MB *** ATI Radeon HD 4850, 1GB Sound Card ATI High Definition Audio *** ATI High Definition Audio Monitor(s) Displays LG Flatron W2053TX Screen Resolution 1600 x 900 (monitor), 1266 x 768 (laptop) *** 2560 x 1440 Mouse Logitech Cordless Optical Mouse for Notebooks Hard Drives 300 GB SATA (internal), 500 GB HP SimpleSave (external) *** 1 TB SATA (internal), 160 GB LaCie (external) Internet Speed Broadband |
11 Jun 2010
#3 | | Windows 7 Home Premum x32 Thundersly, Benfleet, Essex |
updated I think i have added all the info you will need.
Thank you | My System Specs | | Computer type PC/Desktop System Manufacturer/Model Number Medion E6124 OS Windows 7 Home Premum x32 CPU M330 @ 2.13GHz 2.13GHz Motherboard MSI MS-7502 Memory 4 Gb Sound Card HDAudio\FUNC_01&VEN_10EC&DEV_0269&SUBS Monitor(s) Displays Generic pnp Monitor Screen Resolution 1024 X 768 Hard Drives Generic- Multi-Card USB Device Disk Drives
11 Jun 2010
#4 | | Win 7 Ultimate x64 Etobicoke, Ontario |
Brian it sounds like the turntable changed the default recording/input device to itself, not uncommon for that sort of thing. If that is what happen you need to open the Windows recording properties and just change the default back to your microphone.
P.S. Also if that is what happened and you only use the mic for Skype you should be able to right click on it and set it to the default communications device, and then you can leave the turntable as the default recording/input device. | My System Specs | | System Manufacturer/Model Number Me OS Win 7 Ultimate x64 CPU Phenom II x4 955 @ 4 GHz. Motherboard Asus M5A97 EVO Memory 2x2 GB Kingston HyperX DDR3 1600 Graphics Card Sapphire HD 6850 Sound Card Xonar DGX w/ Logitech X-530 Monitor(s) Displays Acer S232HL Abid Screen Resolution 1920x1080 Keyboard Logitech Wave Mouse Logitech G5 v2 PSU Antec Earthwatts 650W Green Case Antec Three Hundred Cooling Cooler Master 212 EVO Hard Drives 120 GB OCZ Vertex 3
500 GB Seagate 7200.12 Internet Speed 24000/1000 |
11 Jun 2010
#5 | | Windows 7 Home Premum x32 Thundersly, Benfleet, Essex |
Many thanks for the help.
But as an old man not really too sure about where to go to change the settings for the windows recording properties.
The same for the mic and the turntable default.
Sorry to be a pain. | My System Specs | | Computer type PC/Desktop System Manufacturer/Model Number Medion E6124 OS Windows 7 Home Premum x32 CPU M330 @ 2.13GHz 2.13GHz Motherboard MSI MS-7502 Memory 4 Gb Sound Card HDAudio\FUNC_01&VEN_10EC&DEV_0269&SUBS Monitor(s) Displays Generic pnp Monitor Screen Resolution 1024 X 768 Hard Drives Generic- Multi-Card USB Device Disk Drives
11 Jun 2010
#6 | | Win 7 Ultimate x64 Etobicoke, Ontario |
Right click on the speaker icon near the clock and select "Recording properties". | My System Specs | | System Manufacturer/Model Number Me OS Win 7 Ultimate x64 CPU Phenom II x4 955 @ 4 GHz. Motherboard Asus M5A97 EVO Memory 2x2 GB Kingston HyperX DDR3 1600 Graphics Card Sapphire HD 6850 Sound Card Xonar DGX w/ Logitech X-530 Monitor(s) Displays Acer S232HL Abid Screen Resolution 1920x1080 Keyboard Logitech Wave Mouse Logitech G5 v2 PSU Antec Earthwatts 650W Green Case Antec Three Hundred Cooling Cooler Master 212 EVO Hard Drives 120 GB OCZ Vertex 3
12 Jun 2010
#7 | | Windows 7 Home Premum x32 Thundersly, Benfleet, Essex |
I cannot see a "Recording properties" on right clicking the Icon i get:
"Open Volume Mixer"
"Playback Devices"
"Recording devices"
"Sounds"
"VolumeControl Options"
None of these change the recording properties next suggestion please. As i'm not sure what to do now.
Reason: needed a bit more info
12 Jun 2010
#8 | | Win 7 Ultimate x64 Etobicoke, Ontario |
Sorry my mistake, meant Recording devices. | My System Specs | | System Manufacturer/Model Number Me OS Win 7 Ultimate x64 CPU Phenom II x4 955 @ 4 GHz. Motherboard Asus M5A97 EVO Memory 2x2 GB Kingston HyperX DDR3 1600 Graphics Card Sapphire HD 6850 Sound Card Xonar DGX w/ Logitech X-530 Monitor(s) Displays Acer S232HL Abid Screen Resolution 1920x1080 Keyboard Logitech Wave Mouse Logitech G5 v2 PSU Antec Earthwatts 650W Green Case Antec Three Hundred Cooling Cooler Master 212 EVO Hard Drives 120 GB OCZ Vertex 3
12 Jun 2010
#9 | | Windows 7 Home Premum x32 Thundersly, Benfleet, Essex |
All sorted. Many many thanks for the help and patience shown. Really appreciated. | My System Specs | | Computer type PC/Desktop System Manufacturer/Model Number Medion E6124 OS Windows 7 Home Premum x32 CPU M330 @ 2.13GHz 2.13GHz Motherboard MSI MS-7502 Memory 4 Gb Sound Card HDAudio\FUNC_01&VEN_10EC&DEV_0269&SUBS Monitor(s) Displays Generic pnp Monitor Screen Resolution 1024 X 768 Hard Drives Generic- Multi-Card USB Device Disk Drives
12 Jun 2010
#10 | | Win 7 Ultimate x64 Etobicoke, Ontario |
500 GB Seagate 7200.12 Internet Speed 24000/1000 All times are GMT -5. The time now is 04:56 AM. | |
