Hello Fourm,
I upgraded my pc today from IDE to SATA and added 3 GB more RAM and 500 GB HD, After a build of the o/s I went into the device manager and found i only needed 1 driver (nice one microsoft), anyway i dug out my MSI drivers CD and ran it in compatability mode as you do, Installed the driver for the sound and after a restart windows does say the device is working properly.
I can see in the volume control panel whilst i play music the green bar is jumping but i am having no audio output. The speakers are plugged into the correct port, they are switched on and volume is not muted but still i get no audio output.
I tried updating the audio drivers, but they are up-to-date, I tried my headphones incase it was an external fault with the speakers but is isnt.
Im starting to think it might be a board fault that might of happened when i changed the housing or something that i might of did wrong in the bios when i over clocked it a little, maybe disabled something.
If anyone has any ideas or knows the answer to this riddle please post me.
- Self Built
- windows 7 home Premium 32 bit
- AMD Athlon 64 x 2 Dual Core 3800+ 2.00GHz
- Motherboard
- MSI MS-7125
- DDR2 4 GB 3.25 usable
- Graphics Card(s)
- Nvidia 6 series 8600 1 GB Onboard
- Sound Card
- onboard realtek
- Monitor(s) Displays
- A Dell Box for now 18 inch
- Screen Resolution
- not enough to stop me eyes from bleeding
- Hard Drives
- 500 GB 32 MB Cash SATA
1 TB External HD
- PSU
- 500 Watt
- Case
- Not into cosmettics
- Cooling
- Fan runs at about 2900 RPM
- Keyboard
- USB Wired
- Mouse
- USB 3 Button
- Internet Speed
- 10 MB
