Windows 7: Fresh Build No Sound
11 Jun 2010   #1
windows 7 home Premium 32 bit
UK
Hello Fourm,
I upgraded my pc today from IDE to SATA and added 3 GB more RAM and 500 GB HD, After a build of the o/s I went into the device manager and found i only needed 1 driver (nice one microsoft), anyway i dug out my MSI drivers CD and ran it in compatability mode as you do, Installed the driver for the sound and after a restart windows does say the device is working properly.
I can see in the volume control panel whilst i play music the green bar is jumping but i am having no audio output. The speakers are plugged into the correct port, they are switched on and volume is not muted but still i get no audio output.
I tried updating the audio drivers, but they are up-to-date, I tried my headphones incase it was an external fault with the speakers but is isnt.
Im starting to think it might be a board fault that might of happened when i changed the housing or something that i might of did wrong in the bios when i over clocked it a little, maybe disabled something.
If anyone has any ideas or knows the answer to this riddle please post me.
11 Jun 2010   #2
Windows 7 Ultimate X64 SP1
Cromer Norfolk UK
Is the sound card/on board sound switched on in the BIOS? I know this sounds REALLY obvious, but its amazing how often its overlooked
11 Jun 2010   #3
UK
nope its set to Auto the only things disabled are the 2 spread spectrums and the floppy stuff.
11 Jun 2010   #4
Windows 8 Pro x64
Sydney, Australia
Have you enabled the correct device in this window
11 Jun 2010   #5
UK
yep it also shows audio levels when i play a sample music file thats the perplexing thing about it.
11 Jun 2010   #6
Windows 7 Ultimate 64bit (Build 7600)
Wales
If you don't mind me asking where did you upload the latest audio drivers from ?
11 Jun 2010   #7
UK
i did an automatic online search with the device manager and it found them no problem.
11 Jun 2010   #8
Wales
Personally I would try and load these drivers
Realtek ALC Series Win7 Drivers
If this doesn't resolve the issue try and update your MB bios (but be careful and follow the directions carefully)
11 Jun 2010   #9
UK
many thanks ill try these
11 Jun 2010   #10
UK
I just cross referenced them and they are the same version. thanks anyway.
 Fresh Build No Sound problems?
Similar help and support threads for: Fresh Build No Sound
Multiple BSOD - Fresh PC Build BSOD Help and Support
fresh build with ATI 4350 gives high CPU on SVCHOST Graphic Cards
Self restart while installing windows with fresh build Installation & Setup
Help! Random Reboots Win 7 x64 Fresh Build BSOD Help and Support
Solved BSOD fresh PC build, IRQL not less or equal BSOD Help and Support
