Low Sound, need booster.
elsuirad
LiveLong & Prosper
Power User
7:22 AM
Somewhere in South Africa
Hello all,
I would like to know if there's any software program that can make the sound quality or more boost to my Laptop's audio output?
All settings are all maxed but I'm not satistfied with the output unless I put it on a headphone but I feel don't like it (wearing a headphone for a longer time).
Just asking if there's need for improvement. ;)
BTW, See my specs below.
Windows® 7 Home Basic 64bit, Build 7600Inter Core 2 Duo CPU T6600 @ 2.20GHz4GBnVidia GeForce G210M
SONY VAIO Laptop
4GB
Realtek HD Integrated Audio
LG TV-1 (NVIDIA High Definition Audio)
1366 x 768 (Wide)
320GB HDD - Internal
360GB - External
500GB (x2) - External
1TB - External
Internal
Synaptic Keypad & A4tech Cordless MOuse
LAN, T1
A4tech Analog Joypad
Windows 7 Home PremiumIntel Core 2 Duo @ 3.00gHz4 GBATI Radeon HD 2600 XT
Assembled in my workshop
Gigabyte GA-P35-S3G
Acer 1917 (x2)
1280 x 1024 on both monitors
Rosewill 500-watt
Rosewill mid-tower
Macally w/2/USB ports.
Trackman Wheel
Did you try the "Enhancements" in speaker properties. Just be aware that those enhancements will use CPU resources. Do you by any chance use the laptop speakers for output - if yes, you cannot expect any quality output. A set of good external speakers may fix the problem.
Yes, already did that 'enhancement thingy' but only a little progress it made. I know it really needs an amplifier or sort of sound system and since I don't have it (yet), I still need to find out how to get it.
Thanks for the response. ;)
SONY VAIO Laptop
4GB
1366 x 768 (Wide)
360GB - External
1TB - External
Internal
LAN, T1
Sound app that worked 4 me
Letasoft Sound Booster
worked 4 my labtop
