Defining tracks with Sound Forge
wwgolfer
4:23 PM
I am using Sound Forge 9.0.
I have tried several times to burn a CD from an edited file.
After about 15 minutes I get tthe message "The disc burn completed without errors." But there is nothing on the disk.
I know the cd burner works as I can copy the files using window, though it comes through with none of the markers/tracks I created.
Any ideas?
windows 7
windows 7
Lets assume you're doing a "save as" before you burn it to a cd.
Are you buring the file as data or music? SoundForge defaults to burning as music.
If you want to save all your markings you must save the meta file with it, as data, which you can do thru Windows.
windows 7 32Intel i7 4770KCorsair Vengeance 8gb DDR3 2133(PC3 17000)nVidia GTX 660 2gb
Homebuilt
windows 7 32
Intel i7 4770K
Asus Z97-A
nVidia GTX 660 2gb
Asus Xonar D1
Dell Ultrasharp UM2913WM
2560x1080 32
PNY 240gb SSD
Seagate 500gb SSD
Corsair CXM 600
Fractal Design Define R4
Arctic Freezer Xtreme rev 2
Logitech K800 Wireless Illuminated
MicroSoft 5000
Cable
IE 11 and Chrome
Samsung DVD-RW
Cambridge 4.1 speakers
Hauppauge HVR-950 USB Tuner
Asus Optimized Overclock to 4.4ghz
There's several selection in Soundforge, do you by any have it set to just run a test burn? This is a simulation, Soundforge will then report... "Burn Completed Without Errors" but the CD will be blank.
Ap
Windows 7 Home PremiumIntel Core 2 Duo @ 3.00gHz4 GBATI Radeon HD 2600 XT
Assembled in my workshop
Gigabyte GA-P35-S3G
Acer 1917 (x2)
1280 x 1024 on both monitors
Rosewill 500-watt
Rosewill mid-tower
Macally w/2/USB ports.
Trackman Wheel
