Digital Output with Realtek Audio
  1. Posts : 30
    Microsoft Windows*7 Édition Familiale Premium 64 bits 7601 Multiprocessor Free Service Pack 1
    Hello Everyone,
    I got a problem and hope that you could help me.
    I have Fujitsu-Siemens Laptop with Realtek Audio card built-in.
    Initially when I open the Realtek Audio Manager it shows Speakers and Digital Output as well.
    I have disabled the Digital Output at certain time, and now cannot find a way to enable it again.
    I've searched in the Control Panel, tried trouble shoot utility from the Control Panel and have got no idea how to enable Digital Output back.
    Any suggestion are welcome, I'll try.
    Thank you
  2. Posts : 1,158
    Win7 HP (x64)/Win7 Ultimate (x64)
    Hi Nguyen
    Have you tried re-installing the realtek driver?
    Regards
  3. Posts : 908
    Windows 7 Home Premium
    Nguyen35 said:
    Hello Everyone,
    Do you also have the Microsoft Speaker Icon in the System Tray...
    Right Click on it and select "Playback Devices", then right click on the Digital Output and select "Enable".
    If you don't see the Digital Output post back, there's a way to make it visible.
    Ap
  4. Posts : 30
    Digital Output
    Aphelion said:
    Nguyen35 said:
    Hello Everyone,
    Ap
    Hello Aphelion,
    I did the right click on the Speaker in the Tray but in the Playback device there is only the Speaker.
    Digital Output is not visible.
    The way to make it visible is what I'm looking for.
    Thanks in advance.
  5. Posts : 30
    Lomai said:
    Hi Nguyen
    Regards
    Yes I did to no avail.
  6. Posts : 30
    Realtek
    Aphelion said:
    Nguyen35 said:
    Hello Everyone,
    Ap
    Hello Aphelion,
    I've found the way to show the Digital Output back under the speaker.
    The fact that you said there is a way makes me think and try some more actions.
    Now it is back, thanks a lot for your input:)
  7. Posts : 908
    Nguyen35 said:
    Hello Aphelion,
    Good work Nguyen! Now, did you right click on it and then select "Enable"?
    Ap
  8. Posts : 30
    Realtek
    Yep! Everything is under control now. The problem was the disappearence of the Digital Output Icon. Thanks.
  9. Posts : 9
    Windows 7 x64
    Nguyen35, how were you able to solve your problem? I am facing the same issue and cannot get the Digital Output option back.
  10. Posts : 1
    Windows Vista
    I had the same problem. Go to Control Panel and open the sound controls, click the Playback tab, then right-click in a blank area where the devices are listed. It will present you with the option of "Show Disabled Devices". Click that and it should show the Digital Output option again. Then follow the other instructions to enable it again.
    It is pretty odd that the previous posts never get around to saying how they actually got it to happen!
