Windows 7: interchanged sound problem
17 Jun 2010   #1
Hey, guyz. i have a HP pavilion dv6 entertainment pc, my speaker used to work before i started to use a headphone. suddenly it stopped working while i waz watching a movie using a headphone, dat waz d first occurence, but waz able to fix it. Later on it stopped working , but this time, when you test the headphone in control panel it sounds through the speaker and it plays through the headphone, when the speaker is set as default. I have tried every means i know, pls i need help. i dnt know how it happened
17 Jun 2010   #2
Windows 7 Home Premium (64-bit) *** Windows XP SP3 (32-bit), OSX 10.6
Quote   Quote: Originally Posted by shakisparki View Post
Do you mean it plays through both the speaker AND the headphones?
How did you fix the issue the first time it happened?
Walker
Windows Outreach Team
20 Jun 2010   #3
No, it doesnt play through both speaker and headphones, normally it plays through headphones alone, but when you test the headphones in {control panel-Hardware and sounds-manage audio devices} , it sounds through the speaker, and when the speaker is tested instead it sounds through the headphones, but the speaker is the default device, while the headphone is the default communication device(the headphone has microphone joined together). The last time, i just kept inserting and removing the speaker cord,in-case it was the jack, then used the sound troubleshooter, and it worked. I am nt sure if thats what maked it work any way. tanx, plz need help
 interchanged sound problem problems?
Similar help and support threads for: interchanged sound problem
Solved How do i fix the sound problem Sound & Audio
Sound card/sound problem questions? Hardware & Devices
Solved Sound problem - need to 'scan for hardware changes' to get sound Hardware & Devices
Windows Media Player Problem - Sound/skipping problem. Music, Pictures & Video
Sound problem serious Sound & Audio
