Windows 7: Stereo Mix problem-can't seem to record any sound?
21 Jun 2010   #1
Windows 7 HP
So im using windows 7 and i seem to have a problem recording sound directly from my computer
1-i showed disabled devices
2-Stereo mix is set as default
there is:
MICROPHONE-i tap my microphone and there is the GREEN bars bouncing up and down
LINE IN-N/A
STEREO MIX-i played some music and the green bars are NOT bouncing up and down...
how do i fix this?
21 Jun 2010   #2
Windows 8, Ubuntu 12.04 64bit, Pear Linux Triple Boot
What program are you using to record? You will need to set it up to recognize what your inputs and outputs are.
Geeve
21 Jun 2010   #3
Windows 7 Home Premium
Quote   Quote: Originally Posted by aimpacc View Post
there is:
LINE IN-N/A
how do i fix this?
You have the RECORDING tab pulled up. Even though it may seem Logical it's wrong.
What you want as the default "Stereo Mix" device is under the PLAYBACK tab.
Then set whatever else you want "Line in" or "Mic" as the default recording device.
Ap
22 Jun 2010   #4
Windows 7 HP
@geeve420
i use the 'sound recorder' in windows and i want to record sound directly from my computer...eg.sounds from youtube, sounds from other websites
@Aphelion
'stereo mix' does not exist in the PLAYBACK tab
22 Jun 2010   #5
Windows 7 HP
EDIT: it works now but everytime i record the sound is epic soft ??? i have to turn it to nearly loudest to get the volume right
22 Jun 2010   #6
re: Stereo Mix
Sorry, yes... in Recording Devices. duh!
When you select Stereo Mix and then select the "Properties" button at the bottom, then the "Levels" tab, what volume is the record level of Stereo Mix.
Ap
22 Jun 2010   #7
Windows 7 HP
its ninety something when i recorded it and i just made it to 100 and i dun think thats gna make much different
22 Jun 2010   #8
What are you feeding it with, what are you recording?
I only have mine set on 20.
There's also Input level controls for Mic, Line-In...etc.
Ap
22 Jun 2010   #9
Windows 7 HP
Quote   Quote: Originally Posted by Aphelion View Post
Ap
i wanna record some of the things i hear from youtube and some other sites which got music i like but u cant download
and does that mean everytime i wanna record sound from that i have to make it to etreme loud??
22 Jun 2010   #10
Ap
Basically... yes!
Turn your speakers down and your playback volume up.
Ap
Do you have any of the
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
