Problem selecting Default Audio Device
  1. Posts : 3
    I'm having a problem with my sound devices. I plug my headphones in, my headphones work fine in other devices, but my computer still runs the sound through the inbuilt speakers instead of through the headphones. The only program I can run through the headphones is WIndows Media Player because I changed the settings in WMP. All my other applications play sound through the in-built speakers at all times, even when the headphones are plugged in.
    I have tried re-installing the latest drivers for my sound card, it's an IDT one. I have also tried to make the headphones my default device when I go into Sound>Playback I click on 'make this the default device' but it doesn't do anything.
    I have tried everything and it's very annoying.
    Any help would be greatly appreciated.
  2. Posts : 1,598
    Microsoft Window 7 Professional 32 bit
    humm...It sounds strange
    Can you try this, don't know if it helps
    Right click to the speaker icon on the bottom right of the screen-->choose volume control option--> un-check on the all device currently playing sounds and choose your headphone
    Hope it works
    Tuan
  3. Posts : 3
    Hi Tuan,
    Thanks for the suggestion. Didn't help at all though. I am using the IDT High Definition Audio CODEC if that helps anyone at all.
  4. Posts : 908
    Windows 7 Home Premium
    jackc4321 said:
    Hi Tuan,
    Does the IDT device have a Control Panel?
    If there is a control available it will probably be located there.
    Some internal audio systems have options for auto-sensing when a headphone is plugged into the Line-Out jack.
    Ap
  5. Posts : 3
    Thanks Aphelion. I tried going through the IDT Control Panel but still wouldn't let me select the headphones as the default device. I ended up going into Msconfig and disabling the IDT service in Startup and Services which ended up fixing the problem.
  6. Posts : 908
    Good job, so the audio card software was working against you?
    Well, it wouldn't be the fisrt time that has happened.
    pancenter-
