Sound system not working
rainieshower
4:02 AM
i am currently using windows 7, dell desktop which was bought recently last december and the audio service was working perfectly fine then. it was only after the computer has gotten virus that the sound system was not working. currently, the computer has got no virus whatsoever and is working perfectly fine, the only problem now tis the sound system.
when i tried to start the windows audio endpoint builder, i received a message that says: Windows could not start Windows Audio Endpoint Builder service on Local Computer. Error 1722: The RPC server is unavailable
when i tried to start the Windows Audio service, i received this message: Windows could not start Windows Audio service on Local Computer. Error 1068: The dependency service or group failed to start.
are there any other ways that i can start these to services?
windows 7
windows 7
Don't know if this will help.
Windows Audio Service depends on:
Multimedia Class Scheduler
Remore Procedure Call (RPC)
Windows Audio EndPoint Builder depends on:
Plug and Play
Make sure the plug and play service is running.
Ap
Windows 7 Home PremiumIntel Core 2 Duo @ 3.00gHz4 GBATI Radeon HD 2600 XT
Assembled in my workshop
Gigabyte GA-P35-S3G
Acer 1917 (x2)
1280 x 1024 on both monitors
Rosewill 500-watt
Rosewill mid-tower
Macally w/2/USB ports.
Trackman Wheel
