realtek HD help please
  1. Posts : 153
    Windows 7 Ultimate 64 bit
    i have the realtek HD audio and i have it set up just right i have my speakers that do all computer sound then i have my front audio that i have a headset plugged in for use with magic jack skype and vent no i have a TV that the speaker broke and i hooked it up to the input on the back and it plays through the speakers and headset is there a way to play it over the speakers only and not the headset??
    i looked on the web for this problem but i dont see it
    any ideas?
  2. Posts : 1,506
    W7 Ult. x64 | OS X
    Unless your audio hardware/software is smart enough to choose between jacks, you'll probably have to unplug the front jack when you don't want to use the headphones and turn off your tv speakers when you dont want to use them. If Windows treats the two jacks as an individual instead of separate then you don't have many options.
  3. Posts : 153
    ok thank you
