Windows 7: NO Audio Output Device is installed.
15 Jul 2010   #11
Finally gave up and bought a PCI sound card. LOL!! Sound works good!!!
15 Jul 2010   #12
Microsoft MVP
Win 7 Ultimate x64
Probably the best idea. From what I have seen those IDT audio chipsets can be problematic at the best of times, and with the limited support that I have seen for them, a sound card will provide less hassle.
Just for curiosity's sake, which sound card did you get?
22 May 2014   #13
I was able to get my Intel DG33TL motherboard's integrated sound to work. I purchased the used Intel DG33TL motherboard last year to replace a failed board. The Creative Labs Sound Blaster PCI512 (SB0150) sound card worked fine with Windows XP Home 32bit up until yesterday when I installed Windows 7 Home Premium 64bit. I couldn't get the PCI512 software to load, so removed that sound card, followed by turning on all audio features in BIOS. At this point Device manager showed all computer hardware working fine except for IDT Audio, Microsoft Teredo Tunneling Adapter, and the Intel Management Engine Interface. Tired of messing around with Teredo Tunneling Adapter and Intel ME Interface in Device Manager, I disabled them both. Intending to quit fiddling with integrated sound, I used the Control Panel's Programs and Features to remove the IDT Audio driver. I missed the BIOS prompt, but decided to continue back to Windows. After logging in I was startled to hear the "Windows starting" tune from my speakers! The Device Manager's the sound controller simply reads "High Definition Audio Device."
Search this Thread:
Advanced Search
No Audio Output Device is Installed
I believe this is an issue regarding an update. I had this issue before and did a system restore to back before I had installed a certain program, and the issue went away. Now however, I do not have a restore point that will go far enough back. I started up my computer today and I was hit...
no audio output device installed
This is my wife's sony vaio, and she has had this problem with no sound on her laptop, when checking the volume control it says no audio output device installed. In device manager it says that she has Intel display audio. I need major help here please.
No AUDIO OUTPUT DEVICE IS INSTALLED, this is the message l got on sound icone since l installed windows 7 l have downloaded it several time the latest one it shows on control panel but not on device manager, l guess this is not really installed but l keep installing it and restat the laptop...
No audio output device installed
I bought a generic computer. It had windows vista installed and it used to display a message that No audio output device is installed . I recently installed windows 7 home premium 32 bit on it but it still says the same thing. I went to properties of it and found following error message.This device...
No audio output device installed...Tried everything, need some help.
All fixed...Hardware issue. Stripped it down and rebuilt it. Booted up and installed the drivers....woohoo I have sound Hi, I have had this problem now for a couple of months. What I have tried: Reinstall windows 7 Update bios Install the realtek high definition audio...
Realtek Audio: No Audio Output Device is Installed
Hello. Im having the dreadful "No Audio Output Device is Installed" problem on my realtek audio. It worked some months ago, but im in no position to do a roll back. Im sure the hardware is just fine, it works with Ubuntu. The computer is a Dell Vostro 430. My OS is win7 64bit. I tried...
