Windows 7: I really need someone to help me with HIGH DEFINITION AUDIO CONTROLLER
05 Jul 2010   #11
The Howling Wolves
Quote   Quote: Originally Posted by kaliboyz View Post
i still can hear the beep, but not window sound.
Is your system under warranty?
If it is relatively new I would take it back and have it fixed. While you are there check out one that is like yours to hear how it is suppose to sound. IMO
05 Jul 2010   #12
As suggested by fireberd....did you uninstall all the high definition audio from "program & features", rebooted and see in devices manager what' it says? Try reinstall the HDA software from your Mfg after that. (i suppose you went through that aswell)
Search this Thread:
Advanced Search
High Definition Audio Controller Disabled
In Device Manager I have 3 references to the High Definition Controller one of these controllers is disabled(black down arrow). I can enable the device and it shows the device working properly and I can check for drivers(it's up to date according to Windows), but when I shut off the system...
System Devices..High Definition Audio Controller. Code 10
Recently build new rig. Specs: i7 3930k Asus Rampage IV Extreme G Skill Ripjaws Z 32gb Samsung SSD PRO 256gb MSI 7970 Crossfire Corsair AX1200i Put build together all went well. After a couple of days downloading drivers began to test hardware. Started with GPU's. Installed amd 13.2...
issue i can disable a douple Controller High Definition Audio
Hi i update my ati drivers and the realtek high definition drivers i have 2 Controller High Definition Audio and i can not disable one one is for realtek the other is of the video card
Hardware & Devices
High Definition Audio Controller not working after Windows 7 Update
Hello, i have a toshiba satellite L505D-S5983 laptop with windows 7 home premium 32bit. everything on the computer worked fine until... Recently I had a windows 7 update. After one of the many updates, my screen went blank and I could not open windows without going into safe mode. Well, i...
High Definition Audio Controller [NoDB]
so i installed 7 and my sound isnt working, cant for the life of me find a codec or driver or anything. i did an everest report on my comp and it showed this " Multimedia: Audio Adapter High Definition Audio Controller Audio Adapter Multimedia Audio Controller " apparently the name of...
High Definition Audio Controller devices - How many?
I updated to the latest Realtek driver. Everythimg runs fine as long as I don't plug the Quickcam Pro 9000 in (different story). But I was checking things out and noticed that I have 2 "High Definition Audio Controller" devices installed in Device Manager>System Devices. This is a Dell...
