Windows 7: I really need someone to help me with HIGH DEFINITION AUDIO CONTROLLER
05 Jul 2010   #1
kaliboyz
7 Ultimate
Hello all,
I'm new to this forum and i need your help.
I have a laptop Inspiron 6400 with Window 7 Home Premium x64 , but my sound is not working, there's a speaker on the right hand corner but has an (X) on the speaker, i checked with the DEVICE MANAGER and saw an yellow (!) on High Definition Audio Controller. i have tried many different ways that i researched on google for the whole week ,but got no luck so can someone help me please? all methods to fix this problem are welcome!!
Thank you very much.
05 Jul 2010   #2
The Howling Wolves
Check this thread out...
dell inspiron 6400 drivers for win 7
Several with same problem.
05 Jul 2010   #3
NoN
In your devices manager did you tried to update the driver on the yellow pointed one (search drivers on my computer, not online)?
05 Jul 2010   #4
kaliboyz
7 Ultimate
NoN : i tried that too and i got this message : "The best driver softwre for your device is already installed . Windows has determined the driver software for your device is up to date"
Still the yellow (!) still on High Definition Audio Controller
05 Jul 2010   #5
fireberd
Uninstall the sound in the Device Manager then restart the PC and when Windows starts it should detect and reinstall it. Sometimes this fixes problems such as this.
In the Device Manager, RIGHT click on the entry for the sound to highlight it and then LEFT click Uninstall. DO NOT check the box to uninstall the drivers. Restart the PC.
05 Jul 2010   #6
NoN
Quote   Quote: Originally Posted by kaliboyz View Post
If you have kept the folder where were extracted the files...you can aswell update the same manner but choose files on my computer folder! see if its works..
05 Jul 2010   #7
hoganth
WinXP / Win 7 / Win 8.1 64bit Dual Boot
Quote   Quote: Originally Posted by NoN View Post
Don't totally trust that the "best driver software for your device is already installed". I ran into that issue with my Dell 170L desktop video driver. Windows update gave me a new driver and I could not get past standard VGA. Rolled Back to original driver (installed in compatibility mode) and got my 1280x1024 back.
Manually install the correct driver if need be from mfg. website
Thanks worked for me with Win 7
05 Jul 2010   #8
kaliboyz
7 Ultimate
NoN : i tried it too, still not working. Please help me guys, i'm very frustrated.
05 Jul 2010   #9
The Howling Wolves
Did the speaker work before? Maybe a defective speaker.
05 Jul 2010   #10
kaliboyz
7 Ultimate
i still can hear the beep, but not window sound.
High Definition Audio Controller Disabled
In Device Manager I have 3 references to the High Definition Controller one of these controllers is disabled(black down arrow). I can enable the device and it shows the device working properly and I can check for drivers(it's up to date according to Windows), but when I shut off the system...
System Devices..High Definition Audio Controller. Code 10
Recently build new rig. Specs: i7 3930k Asus Rampage IV Extreme G Skill Ripjaws Z 32gb Samsung SSD PRO 256gb MSI 7970 Crossfire Corsair AX1200i Put build together all went well. After a couple of days downloading drivers began to test hardware. Started with GPU's. Installed amd 13.2...
Drivers
issue i can disable a douple Controller High Definition Audio
Hi i update my ati drivers and the realtek high definition drivers i have 2 Controller High Definition Audio and i can not disable one one is for realtek the other is of the video card
Hardware & Devices
High Definition Audio Controller not working after Windows 7 Update
Hello, i have a toshiba satellite L505D-S5983 laptop with windows 7 home premium 32bit. everything on the computer worked fine until... Recently I had a windows 7 update. After one of the many updates, my screen went blank and I could not open windows without going into safe mode. Well, i...
High Definition Audio Controller [NoDB]
so i installed 7 and my sound isnt working, cant for the life of me find a codec or driver or anything. i did an everest report on my comp and it showed this " Multimedia: Audio Adapter High Definition Audio Controller Audio Adapter Multimedia Audio Controller " apparently the name of...
High Definition Audio Controller devices - How many?
I updated to the latest Realtek driver. Everythimg runs fine as long as I don't plug the Quickcam Pro 9000 in (different story). But I was checking things out and noticed that I have 2 "High Definition Audio Controller" devices installed in Device Manager>System Devices. This is a Dell...
