Are sound cards worth it?
snipermouse
2:07 PM
hi all, with todays mobo's and onboard HD sound are sound cards still worth the money?
I'm currently looking at a Creative Sound Blaster X-FI Titanium PCIe Fatal1ty Pro for around $175 AUD. My pc is mostly used for gaming and listening to music. I'm pretty fusy when it comes to sound quality and not real happy with the music quality out of itunes. Gaming sounds good though espesially in BFBC2 (sounds awsome, but thats in the game with 1 processor taken up by sound alone...great job EA!!!) The speakers i have at the moment are a pair of logitech desktop speakers and a floor sub. Would buying better speakers improve the sound or should i upgrade to a soundcard and new speakers??
Any thoughts guys would be great on brands, setup and experiences good or bad?
Are the drivers for sound cards a pain in the a*#s??
Almost forgot, whats the power draw on these things?
cheers
Win 7 64biti7-3770K @ 4.5Ghz16GB CORSAIR DOMINATOR PLATINUM @2133Mhz2x EVGA GTX680 SC SLI
CUSTOM
Win 7 64bit
i7-3770K @ 4.5Ghz
ASUS SABERTOOTH Z77
CREATIVE SOUND BLASTER X-Fi TITANIUM HD
DELL U3011 / SAMSUNG S27A950D 120Hz
2560X1600 / 1920X1080
INTEL 520 SSD 240GB
CORSAIR AX1200
CORSAIR AIR540
CORSAIR H100i
CORSAIR VENGEANCE K90
LOGITECH G9x
G'day mate :D
Lots of opinion out there but ones that matter:
  1. Dedicated sound-cards offloads work from the CPU - may improve your frame-rates in games
  2. Am no audiophile but sounds tends to be sharper and clearer on good add-on cards
Note that some add-on sound-cards are no better than on-board though, especially on newer mobo's. This of course is my opinion.
Someone on another forum site stated the following:
Humans CANNOT perceive the difference in sound quality between modern on-board and sound cards.
The only thing that makes sound different is speakers/headphones.
The only reason to spend $$ on sound card is features (digital in/out)
Anyone who argues with me needs their brain checked.
:p
Hope this helps
Win7 HP (x64)/Win7 Ultimate (x64)Core i7 9206 x 2GB Corsair XMS3CF HD4890
Core i7 920
Intel X58
CF HD4890
Asus Xonar
Dell 2408WFP
1920 x 1200
2 x 150GB WDC Velociraptors (Raid 0)
1 x 1TB Seagate
1 x 1.5TB Seagate
Corsair HX1000W
Antec 1200
Razer Lycosa/N52te
Razer Lachesis
It is a very good card for audio listening as well as gaming. I have no issues with it. You can read my thoughts about it here.
Yes, its worth it :thumbsup:
My opinion :)
Windows 10 ProIntel Core i7-4770K (3.5Ghz)32 gig Corsair Dominator Platinum (4x8Gig)Sapphire Tri-X R9 Fury
Custom built by me.
Windows 10 Pro
Soundblaster ZXR
NEC PA242W 24" LCD Monitor
1920 x 1200
EVGA Supernova 1000 G2
Cooler Master HAF X
Logitech Wireless Wave
Logitech Performance MX
High Speed Cable
Norton Security
IE11
Sorry, but I have to disagree. I'm a music lover and loath MP3's because they tend to sound bright and thin to me. Other say they can't tell a difference, but I can, so that's all that matters.
Same goes with cheap mastered CD's. I tend to go for the audiophile types because to me they simply have more depth and range.
I will admit that I've never used my motherboard's on-board soundcard, so I can't tell you how good it is. On the other hand don't need to listen to a cheaply made stereo amp to know it's no good.
Anyway sound is a matter of opinion.
My two cents.
Custom built by me.
Windows 10 Pro
Soundblaster ZXR
1920 x 1200
Cooler Master HAF X
High Speed Cable
Norton Security
IE11
G'day mate :D
:p
Hope this helps
The person who made the quote above is an idiot, don't waste brain cells even thinking about such a ludicrous statement.
Having used PC's (Amiga, Mac & PC) for music/audio for the past 20 years I can tell you there's a huge difference in quality between a pro card and onboard audio.
For one thing.... the noise floor on motherboard audio is atrocious. Bass is less defined and highs are either muffled or slightly distorted... of course, this depends on what you're used to listening to. If Mp3 files are your pinnacle audio experience then onboard audio is probably fine, that is.... until you hear a really good PC audio system and realize what you've been missing.
Considering the circuitry that's found on a modern motherboard, plus the close proximity of the audio chip/device, it's a wonder onboard audio sounds as good as it does.
Ap
Windows 7 Home PremiumIntel Core 2 Duo @ 3.00gHz4 GBATI Radeon HD 2600 XT
Assembled in my workshop
Gigabyte GA-P35-S3G
Acer 1917 (x2)
1280 x 1024 on both monitors
Rosewill 500-watt
Rosewill mid-tower
Macally w/2/USB ports.
Trackman Wheel
Uhhh... We can agree to disagree agreeably. No need to hurl insults. Notice I disagreed and did it respectfully, and without insults.
Be nice.
Peace :cool:
Custom built by me.
Windows 10 Pro
Soundblaster ZXR
1920 x 1200
Cooler Master HAF X
High Speed Cable
Norton Security
IE11
thanx guys for your input, i think its gona be a case of suck it and see. Have heard great reviews of that card and i think ill give it a go. Sygnus21, that is a great review also,cheers for that. Checking my system specs, will i have enough power to run the extra card with my 750w PSU?
CUSTOM
Win 7 64bit
i7-3770K @ 4.5Ghz
ASUS SABERTOOTH Z77
INTEL 520 SSD 240GB
CORSAIR AX1200
CORSAIR AIR540
CORSAIR H100i
LOGITECH G9x
cheers
I have heard that those cards work well for gaming, but I have no idea how they work for music.
Gigabyte Technology Co., Ltd.
Intel Core 2 Duo E8400
Gigabyte GA-EP35-DS3R
NVIDIA GeForce 9400GT
HP 2009m(primary), Acer P191W
1600x900, 1440x900
500GB Toshiba portable drive
Antec Earthwatts EA500D
Antec Sonata III
4 fans
Logitech Wave
Logitech M-SBF90
MSE, Hitman Pro, Malwarebytes
Chrome and Palemoon
Laptop....Acer 5750Z-4835
Be nice.
Peace :cool:
:shock: Heh... it wasn't anyone on this board nor poster Lomai who posted the quote. The "insult" wasn't directed at anyone in this thread or even on this forum.
One can be peaceful and at the same time, not suffer fools lightly.
But you do have a point. How is this?
I strongly object to the quote comparing motherboard audio to 3rd party pro, or semi-pro audio solutions.... Are you daft man!
Ap
Gigabyte GA-P35-S3G
Acer 1917 (x2)
Rosewill 500-watt
Rosewill mid-tower
Trackman Wheel
That's not even a problem, you could run that card on a 350watt PS.
But... to give you comfort, when I bought the card my then system had a 550watt PS :)
It's a good card with great sound quality.
Enjoy.
Custom built by me.
Windows 10 Pro
Soundblaster ZXR
1920 x 1200
Cooler Master HAF X
High Speed Cable
Norton Security
IE11
A dedicated sound board will always provide more performance and better sound quality. However, whether or not you will hear that much difference depends upon your ear, your speakers or headphones. But if dedicated sound boards were not needed, they wouldn't be sold today...nor be priced as high as what they are.
Windows 7 Ultimate x64Intel Q9550 2.83Ghz OC'd to 3.40Ghz8GB G.Skill PI DDR2-800, 4-4-4-12 timingsEVGA 1280MB Nvidia GeForce GTX570
Self-Built in July 2009
23" Acer x233H
Intel X25-M 80GB Gen 2 SSD
Corsair 620HX modular
Antec P182
stock
ABS M1 Mechanical
Logitech G9 Laser Mouse
15/2 cable modem
pparks...
You've inspired me to clean out my machine and redo the wiring today.
Better ventilation is a plus as well.
Nice job.
Ap
Gigabyte GA-P35-S3G
Acer 1917 (x2)
Rosewill 500-watt
Rosewill mid-tower
Trackman Wheel
I use the on-board audio, and am perfectly satisfied with it. I understand what people are saying about sound cards, and I agree that if you want better quality audio than what is provided by the motherboard that it is the way to go. However, it is also important to check whether or not you can get driver updates for the card.
Dwarf Dwf/11/2012 r09/2013
Windows 8.1 Pro RTM x64
ASRock Z77 Extreme4-M
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
Gigabyte IF233
Avast! 8.0.1497
IE 11
Well luckily creative does keep these drivers updated and working so that's not an issue with the card either :)
Get the card, you wont regret it.
Custom built by me.
Windows 10 Pro
Soundblaster ZXR
1920 x 1200
Cooler Master HAF X
High Speed Cable
Norton Security
IE11
It all depends on your preferences.
Logically...If you have a couple factory speakers that can't handle much and don't sound that good, then no.
If you are planning on upgrading your speakers, or if you have a nice speaker system with a sub & maybe surround sound, then yes, it would be worth it.
Like I said, depends on your preferences and what you have.
Dell Hell oh Well
Intel Core 2 Duo 2.93GHz
Not much with my ADHD
ATI Radeon HD 4350
24" HDTV/Monitor
Blurry after a Scotch or 2
Don't get on my case...man :D
Saitek Cyborg
Never fast enough
Various
Various
First of all I agree with sygnus21, there is no need for disrespect or arguing. After reading all the post I still don't know which is better. May be we should try the subject again.
i agree with Borg above, a lot depends on the quality of your speakers.
if your speakers aren't up to the job, you won't hear the full benefit of the improved source. it may then be better to upgrade your speakers first, if money is tight, before upgrading the soundcard.
good soundcard + poor speakers = poor sound
simply put, better speakers are sure to sound better, even with your mobo soundchip.
you'll get the best results running your sound through a hi-fi amp and speakers, as far as music goes.
i use got two sound systems: i split the front stereo output from my x-fi - one pair goes to my hi-fi for listening to music, the other goes to a 5.1 system for gaming and movies.
ultimate 64 sp1i5 2500K [email protected]8 gigs GSkill Ripjaws 1600amd hd6950
mickey megabyte 1234
ultimate 64 sp1
MSI P67A-GD53
amd hd6950
creative x-fi gamer
samsung 24"
antec 550
antec three hundred
i'm a cooling fan
saitek eclipse ii
logitech g3
about 4 Mbps
i love win7
It's perfectly clear, a good add-on third party audio card will most certainly have better audio than the motherboard's onboard audio chip.
However, is better sound going to be worth $100, $200, $300 or more to you?
If you have only average speakers then a new audio card will not really show much improvement. It also depends on what you need from your system and what you're going to listen to? What Are your requirements?
The point is, neither is "better", if you're not concerned with critical listening or only an average gaming experience, built-in audio is better, and doesn't cost anything. If you want more depth, clarity and realism then I would say a 3rd party PCI or PCIe audio card is the way to go.
Personally, a good argument with a bit of passion involved is often where the most useful information is imparted, that is, if one can not be offended by any minor transgressions. I am not the politically correct guy.
Ap
Gigabyte GA-P35-S3G
Acer 1917 (x2)
Rosewill 500-watt
Rosewill mid-tower
Trackman Wheel
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
Gigabyte GA-P35-S3G
Acer 1917 (x2)
Rosewill 500-watt
Rosewill mid-tower
Trackman Wheel
