Windows 7: Sound events playback don't overlap, causes problem...
17 Jul 2010   #1
Can we allow Windows 7 sound events playback to overlap? If not, can this capability be added in the future? Currently, custom sounds that are long [~1-2+ seconds] are interrupted or don't play in situations where multiple sounds are triggered quickly [such as for menus]. If sound events playback can overlap, this wouldn't be a problem and we would have more choices for custom sound effects.
BTW: I wanted to assign sounds that have an echo effect to sound events but unfortunately these are amongst the longer sounds that don't work properly.
17 Jul 2010   #2
Windows 7, 64 bit Home SP1, Win 8.1.1 Pro 64 bit
We are not Microsoft, if you want a feature, you need to contact Microsoft direct with your suggestion.
It would take some very custom programming to do what you want.
Similar help and support threads for2: Sound events playback don't overlap, causes problem...
Min/Max/Close icon overlap problem with custom themes Themes and Styles
Voice Events instead of Sound Events Chillout Room
I can't use custom sound events Sound & Audio
Issues with sound and playback Sound & Audio
Sound Application for playback Sound & Audio
No sound for my events Sound & Audio
No Sound on DVD playback Sound & Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
