Front Left Speaker problem
niBBit
8:55 AM
I have a Speedlink Medusa 5.1 Pro Gamer Headset (no USB just jack cable) i have and X-Fi XtremeGamer Fatal1ty Pro Series soundcard. Yesterday i was listening to some music not doing anything at all and suddenly my front left speaker sound was dropping like every few seconds it was like turning off the sound from the speakers real quick and now the front left speaker is not working anymore :confused: if i go to the sound setup all the sound levels of all the speakers are all the way up and if i go to the speaker setup and test my speakers (5.1) the sound from the front left speaker is really really really low you can just barely hear it. i'm really confused here because i was not doing anything besides listening to music and surfing the web and also i tried to reinstall the drivers but that din't work also is it maybe that my speakers are broken or my soundcard is messed up or is it maybe software related?
Windows 7 HomeIntel(R) Core(TM) i7 860 @ 280GHz4GBHD 5770
Windows 7 Home
P7P55-M
4GB
HD 5770
Hi niBBit,
Try swapping your front and rear speakers over (swap the plugs) so that your LF is now your LR and RF your RR. Test your speakers again. Are you now getting sound out of your LF with little to none out of your LR? If Yes then it could be your speaker (possibly a flakey connection in the plug), but if No(and your LF output, which is now connected to your LR speaker) is still low then it could be a soundcard and/or driver problem.
Dwarf Dwf/11/2012 r09/2013
Windows 8.1 Pro RTM x64
ASRock Z77 Extreme4-M
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
Gigabyte IF233
Avast! 8.0.1497
IE 11
hey thx for replying. I tried what you said i swapped the plugs and went to the sound setup the one witch you can choose how many speakers and test them etc and i clicked on the left speaker icon (Front Left) and it played a sound YAY! and my other left was playing no sound so i was like ok so thats the problem BUT i went to my music player (Foobar) and played a song....sound is't coming from the front left anymore :confused:
Windows 7 Home
P7P55-M
4GB
HD 5770
OK. Disconnect all your speakers and just reconnect the rear ones to the front sockets. Set your card to Stereo mode and try again.
Gigabyte IF233
Avast! 8.0.1497
IE 11
Nope din't work
Windows 7 Home
P7P55-M
4GB
HD 5770
