Help? No Sound from Internal Speakers!
AngelicaC
6:25 PM
Hello there from the Midwest! So I recently had a virus which took out one of the drivers on my computer, thus not allowing me to Start Windows Normally, in Safe Mode with Networking or anything other option. So, I upgraded to Windows 7 Ultimate. Now, everything is running smooth, except I have not sound coming from my internal speakers. I tried going here, Control Panel\Hardware and Sound\Devices and Printers , to which I saw that my HP Compaq DC 7800 needs troubleshooting. I right click to do troubleshooting and it finds that I need PCI Simple Communications Controller as well as the PCI Serial Port. I tried to install the fixes and that was no luck! Now my question is... What in heavens do I do? I really miss listening to my music every morning.
Windows 7 UltimateE4500 @ GHzRAM Two GBCannot find at the moment..
Intel Core 2 Duo
Windows 7 Ultimate
E4500 @ GHz
Win32 by HP
RAM Two GB
COMPAQ
This is your computer?
You installed the 32bit or 64bit version?
HP Compaq dc7800 Convertible Minitower PC
And you've gone to this page?
HP Compaq dc7800 Convertible Minitower PC -  Download drivers and software - HP Business Support Center
Win 7 Ultimate wasn't listed so I followed the links from Win 7 Professional (32-bit).
The index page is here.
It looks like the first two upgrades for Win7 are BIOS and Chipset drivers and that sounds to me like a good place to start as both of these will help Windows 7 correctly identify the hardware on your computer.
I would first install the chipset drivers which are basically inf files that correctly describe the hardware configuration. A BIOS upgrade is a little more tricky if you've never done one before, I would visit the Hardware & Devices sction of this forum and post a question (re: BIOS Upgrade) there.
Don't know if there's an easy fix as it looks like a couple of things need to be updated first.
Go for the chipset drivers and see if Win 7 recognizes your hardware.
Also, one other question... did you install Windows 7 over the top of your previous operating system or did you wipe (format) the drive and do a fresh install.
Ap
The first two
Windows 7 Home PremiumIntel Core 2 Duo @ 3.00gHz4 GBATI Radeon HD 2600 XT
Assembled in my workshop
Gigabyte GA-P35-S3G
Acer 1917 (x2)
1280 x 1024 on both monitors
Rosewill 500-watt
Rosewill mid-tower
Macally w/2/USB ports.
Trackman Wheel
I installed over my Windows Vista Business, 32 bit. Mine looks more like this >> HP Compaq Business Desktop DC7800 http://lh3.googleusercontent.com/ox...P3ul7ITZGdM-f2sj6oMFfh6DGcaEBxF_B1GAvn-GUhe3y The rest of the specs I could pull up are in my profile. My friend did the installation, so I think that he did the 32 bit installation. The thing is the it doesn't even recognize my audio hardware when I troubleshoot. and, "I tried going here, Control Panel\Hardware and Sound\Devices and Printers , to which I saw that my HP Compaq DC 7800 needs troubleshooting. I right click to do troubleshooting and it finds that I need PCI Simple Communications Controller as well as the PCI Serial Port."
Intel Core 2 Duo
Windows 7 Ultimate
E4500 @ GHz
Win32 by HP
RAM Two GB
COMPAQ
If you want to check which version you have, open the start menu, right click My Computer and click properties. Look at what it says for system type.
Windows 7 Professional SP1 64-bitIntel Core i5-2450M @2.5 GHz6 GB DDR3 1333MHzIntel HD 3000
Toshiba P775-S7100
6 GB DDR3 1333MHz
Intel HD 3000
Built-in 17.3" LED; 22" Insignia NS-L22Q-10A
1600x900; 1360x768
750 GB Hitachi
1TB Seagate FreeAgent External
Verizon DSL Speed(Down/Up): 3360 Kbps / 800 Kbps
MSE and MBAM Pro
IE10
Windows 7 Pro X64 SP1Intel Core I7-3930k16 GB Gskill DDR3-2133eVGA GTX680
homegrown
Intel Core I7-3930k
Asus P9X79 Pro
eVGA GTX680
Creative X-Fi Titanium
As PA246Q
1920 X 1200
Corsair Force GT, 120 GB
WDC 1.5TB Caviar Black
PCP&C Silencer 750 Crossfire
Silverstone FT02
Noctua NH-D14
cheap Logitech USB
Microsoft Intellimouse Explorer (old optical) USB
6Mb cable
Pioneer BDR-205
Samsung SH-203B
Monsoon 5.1 speakers
Seriously, thank you SO much Bobkn. The driver worked after download and restart of system. I am very grateful for your help! (:
Intel Core 2 Duo
Windows 7 Ultimate
E4500 @ GHz
Win32 by HP
RAM Two GB
COMPAQ
