No sound from built in speakers, but sound from headphones
mungylee
12:19 AM
I have a Lenovo S10-3 Netbook, running on Win7 starter.
It has been running fine unil a few days ago, when the built in speakers no longer play any sound. Works fine with earphones or exernal speakers, but not internal speakers.
Drivers are all up to date, and audio/sound settings are all set to full.
And according to the speaker and sound card 'properties' - "This device is working properly."
What can i do?
Windows 7 Starter
Windows 7 Starter
Do you get sound with the external speakers unplugged?? Usually laptops will disable the built in speakers while external speakers are being used... ;)
LENOVO K450 @3.0GHZ
64-bit Windows 8.1 Pro
LENOVO
12.00 GB
Intel(R) HD Graphics
Intel HD integtrated
HP 25' ISP Monitor
100mb down/10mb up
Nope. nothing plugged in. no headphones or external speakers. Volume turned up full on audio settings and on netbook itself.
Still no sound:cry:
Windows 7 Starter
Windows 7 Starter
Delete the sound card in Device Manager, reboot, let Windows reinstall the drivers and see if that helps.
Windows 7 Home Premium x64Intel Centrino Core2 Duo @ 2 GHz6 GB SDRAMATI Mobility Radeon 4650 HD
Toshiba Satellite P505-S8945
Toshiba
6 GB SDRAM
Conexant Pebble HD Audio
1680x945
Toshiba MK5055GSX 453 GB
Seagate 1 TB external HDD
Unicomp Mechanical IBM Model M clone
Wireless Logitech Trackman Marble Wheel
30-40 Mbps
Avira Antivirus Pro
Pale Moon, Opera
