HT Omega Claro Plus Installation Problem
  1. Posts : 1
    Win 7 32 Bit Ultimate
    My OS is Windows 7 Ultimate 32 bit.
    Firstly, I installed SW and drivers from the CD. Then, I downloded sw package from yor web page, and updated drivers. However, the utility sw does not appear in the programs section of windows. There is a folder "HT Omega Claro" under
    C:\Program Files
    Advance
    Driver
    Cmiainfo.sys
    CmilnstallAudio
    CmilnstallAudio64
    CmiSetupConfig.dll
    but I am not able to run sw. How can I solve the problem? Really, I spent several hours and I am exhousted of trying to install the program.
  2. Posts : 9,537
    Did you download any and all of the driver's from the Manufactures sites?
    Seems like this is one of the problems new Window 7 owner's have.
    Check them out and post back so we can go from there.
    Welcome to Windows 7 Forum!
  3. Posts : 232
    Window's 7 Ultimate 64bit
    c81773w7.zip Use drivers of the web it even says on the web site that the bundled Cd does not include the W7 drivers so I think you have to do a clean of all the original drivers you installed of the bundled cd and start over. i have the Striker 7.1 and had no issues at all installing with the drivers of the web site good luck.
