Windows 7: start navigation sound (continuation from Sound & Audio)
29 Aug 2010   #11
i've noticed something...
couldnt it be WLMessenger? i have the WLM sounds disabled but when it logs in it makes that same sound... i believe it is when it loads the ads on the bottom...i think it could be that
EDIT: i found it. it is from msn today.
somehow its an WLM error. when i login into WLM it should open MSN today but it doesnt, however the window is somehow open and reloading every now and then on background, i just cant see it.
reinstalling WLM
29 Aug 2010   #12
Borg 386
Glad you found the probable program that's launching
I wasn't trying to say you definitely had a virus, but it doesn't hurt to eliminate the possibilities.
It could be anything that's launching, could be Live doing a background update, could be the Google toolbar...could be a number of things.
I hope WLMessenger to be the culprit. If it doesn't, then it's time to look at all the processes running and once you hear the sound, see if any new process has launched.
29 Aug 2010   #13
no sound since i turned off msn today. Thank you for your help and im glad it wasnt a virus or something worse!
10 Aug 2012   #14
Windows 7 - 64
Gmail Notifier Plus
I noticed the incessant clicking sound that I identified as the 'start navigation' sound in windows 7. It happened about every minute until I shut off my Gmail Notifier Pro and viola, no more clicking...
Search this Thread:
Advanced Search
how to delete windows navigation start sound.
i have a problem with my windows 7. i wanted to disable the navigation sound for windows explorer and internet explorer, after i choose 'none' for the option, there will be a 'unsaved theme' created automatically. so can i just delete 'Windows Navigation Start.wav'? if yes, can anyone tell me...
HOW TO FIX Continuous "Start Navigation" Clicking Sound
Recently I had this continuous "Start Navigation" clicking sound issue. It's is occured when your computer start making clicking sound even when you're doing nothing. The sound came from your speaker, not a physical sound from any of your hardware. The 'Clicking sound' sounds exactly like when...
start navigation sound and internet explorer 9
I just installed internet explorer 9 and now my start navigation sound doesn't work. I went to sounds and the start navigation sound is enabled and plays just fine when I preview it. I have the X-FI sound card and sound enhancements is disabled also. I had to have that disabled for it to work with...
start navigation sound playing for no reason
a couple days ago i started noticing that my laptop playins the "start navigation" sound randomly, sometimes even when im not on the PC. i do not use IE, and firefox doesnt use that sound, so a page reloading itself isnt the cause, i even tried shutting down firefox and it keeps playing the...
Windows 7 Navigation Start Sound Not Working
I just got a new Dell Inspiron 1545, and upon startup for the first time, the click sound for navigation start is not least on a regulas basis. Once in a great while it will work. I know where to change the sound and disable it, and that does work, but the factory sound of "navigation...
Start navigation sound
One thing that win7 is annoying me about is that I hear the 'Start navigation' sound even when I'm not clicking on anything, maybe while browsing, or even on idle desktop, even while i'm writing this i've heard it two times already!:mad:
