Windows 7: start navigation sound (continuation from Sound & Audio)
28 Aug 2010   #1
Portugal
continuation from this thread:
start navigation sound playing for no reason
here's the Highjack log file:
28 Aug 2010   #2
Windows 7 Home Premium
Southwest U.S.
There'a a lot of junk running that seems unneceesary, first thing I would do is download Malwarebytes free edition and run a full scan. Best thing about Malwarebytes is: When you shut it down it's off, no processes running in the background.
Ap
28 Aug 2010   #3
Portugal
ran the malwarebytes.
no malware detected
28 Aug 2010   #4
Windows 7 Home Premium 32 bit
In a house with a cat trying to kill me
Is your UAC enabled? I would change it to "Always Notify", that may give you a clue as to what is trying to run. This won't always help if you have malware/virus, but it may point out what's running.
Download and run MSE, do a full scan.
As Aphelion said, there seems to be a lot of stuff running. Unless you need all this software, you may want to go to MSConfig and see what is starting up and maybe trim some of it down.
If you want to take a closer look at the current processes running, d/l Process Explorer and run it as Admin
Windows Sysinternals: Documentation, downloads and additional resources
28 Aug 2010   #5
Portugal
i have ESET SmartSecurity 4, always up to date.
and it doesnt find any virus, should i uninstall it and install MSE?
28 Aug 2010   #6
You can install MSE. It will give you a warning that running 2 AV's isn't recommended, but it seems to play well with other AV's according to posts I've seen.
I've seen MSE catch things that the "paid" AV's don't. It integrates well with Windows & uses low system resources. I would trust it over the paid versions.
28 Aug 2010   #7
Portugal
installed, updated, and running a scan.
lets see.
29 Aug 2010   #8
Portugal
MSE doesnt work.
it put my PC SOOOO SLOWWWW that i couldnt even open the start menu.
had to hard reboot my pc 2 times and then uninstall it
EDIT: before that i managed to finish the scan, which found an trojan on the internet temp files and removed it, but i doubt it was that what is making the noise.
29 Aug 2010   #9
Very odd...that's the 1st instance I've heard of MSE slowing down a system. Apparently it was fighting with something there. Or something was fighting it.
You might want to try yanking the existing AV out & just run MSE and see if you get the same results.
Be aware that MSE, in some instances, won't install properly on a system that has certain files already compromised by a virus/worm.
You can also try the AVG Rescue CD, it runs at boot up and scans the system before anything loads.
AVG - AVG Rescue CD Guide
Or d/l the Process Explorer and take a hard look at all the processes running in the background.
29 Aug 2010   #10
Portugal
ok, i unistalled ESET and reinstalled MSE. Re running a scan... If it doesnt find anything im going to reinstall ESET
 start navigation sound (continuation from Sound & Audio) problems?
Similar help and support threads for: start navigation sound (continuation from Sound & Audio)
Solved start navigation sound and internet explorer 9 Sound & Audio
start navigation sound playing for no reason Sound & Audio
Solved Windows 7 Navigation Start Sound Not Working Sound & Audio
Start navigation sound Sound & Audio
how to delete windows navigation start sound. Sound & Audio
