Windows 7: System Protection not working in System Control Panel
14 Feb 2013   #1
sec2709
windows 7 64 bit
I've tried to open System Protection in System in the Control Panel but it will not work. It gives an error of 0x81000203. I've rebooted and attempted but get the same thing each time.
14 Feb 2013   #2
Jacee
Microsoft MVP
Windows 7 Ultimate 32bit SP1
Follow instructions on this page error code 0x81000203__ - Microsoft Community
Scroll to the 2nd answer by Meghmala
14 Feb 2013   #3
cottonball
Windows 7 Home Premium
sec2709,
Also, let's take a look at what is going on with your system...
Please download RogueKiller:
Tlcharger RogueKiller (Site Officiel)
When you get to the website, go to where it says:
(Download link) Lien de téléchargement:
Select the version that applies to your system: x64
Click the dark-blue button that applies to download.
Save to the Desktop
Close all windows and browsers
Right-click RogueKiller and select 'Run as Administrator'
Press: SCAN
A report opens on the Desktop: RKreport.txt
Please provide the RKreport.txt (Mode: Scan) in your reply.
(Please do not delete anything!)
Also, download Farbar Service Scanner
Save to the Desktop
  • Make sure the following options are checked:
    • Internet Services
    • Windows Firewall
    • System Restore
    • Security Center
    • Windows Update
    • Windows Defender
  • Press: Scan
  • FSS creates a log, FSS.txt, on the Desktop.
Please provide the FSS.txt in your reply.
14 Feb 2013   #4
sec2709
windows 7 64 bit
Fixed
Thanks much!
15 Feb 2013   #5
Jacee
Microsoft MVP
How did you fix the problem?
15 Feb 2013   #6
sec2709
windows 7 64 bit
Removed a program titled "Tune Up 2013". It had many components but would not allow me to dis-engage it, which irritated me, so I removed it and then my system protection worked fine.
thank you so much!
15 Feb 2013   #7
Jacee
Microsoft MVP
Very good!
Search this Thread:
Advanced Search
Unable to access Display in Control Panel and System Restore
Hi I'm suddenly finding that I'm unable to open Display and others (e.g. System) in Control Panel on my laptop running Win7 professional 64 bit.. If I try a system restore I get an 0x80042302 error message ref. the Volume Shadow copy service. If I then try to run Services.msc as administrator...
General Discussion
Control Panel\System and Security\System BIOS Version\Model?
Since I have a clean installation of Windows 7, it no longer shows me my Acer specs in Control Panel\System and Security\System, can I get it back some how? Something to do with my drivers not being signed? Or something?
General Discussion
System Image is not recognized in Control Panel\...\Backup and Restore
I have a 256Gb SSD partitioned into 121GB (Volume label left at default "Local Disk") (C:) and 116 GB Data (D:) (sizes select by default in initial access to Disk Management). I also have an internal SATA 6Gb 500Gb Backup (E:). Apparently this label of my E: drive is both "meaningless" and...
Backup and Restore
system protection not working properly
hi guys, i opened system protection today to find it hasnt been making restore points and that there was an error when i tried to set it up. My system came with Vista which I then set up to dual boot with 7, and then following that, I deleted Vista altogether. In system restore, I can see ...
General Discussion
Quick question about 'System' page in Control Panel
Hello, all. Just a quick question, but is there any way to remove the line of text saying "Pen and Touch: No Pen or Touch Input is available for this Display" from the System page in Control Panel? All 3 of my machines have this text, and none of them use any touch devices, so I'd like to...
General Discussion
can't access SYSTEM in control panel
All of a sudden, I can't access the SYSTEM window under control panel or from anywhere else, and anything within system I cannot access either, when I click on SYSTEM in control panel, nothing happens. Everything else in control panel works as it should. For example, if I click on "Change name of...
Performance & Maintenance
