Video Card - Stress Test with Furmark
Page 2 of 7 FirstFirst 1234 ... LastLast
  1. Posts : 513
    Windows 7 Ultimate 64-bit
    Jonathan_King said:
    Passed, yes; problem identified, perhaps. 100C is quite high, even for a GPU. nVidia GPUs can supposedly reach 105C safely, but reports have temperatures in the lower 90s causing problems as well.
    I'd say work on bringing those temps down; use a can of air to blow out heat sinks, fans, and air vents.
    It got to 100 C after half an hour. Is it still a problem?
    Can you please explain can of air?
    And I would like to remind that this is a notebook.
  2. Posts : 3,253
    FurMark 1.9.0 - February 25th, 2011
  3. Posts : 513
       #12
    I am not sure if I got your point. Are you referring to 100 C issue. In this version, 100 C has been set as an up limit and plays a sound when reached. Is this what you mean, or there is another thing? Thanks.
  4. Posts : 3,253
    No I was just posting the newest version of Furmark as it adds support for newer video cards. (eg gtx 500 series)
  5. Posts : 513
       #14
    Oh, ok. Thank you very much for the link. I installed it.
  6. Posts : 13,354
    Windows 7 Professional x64
       #15
    Can of compressed air:
    Because you have a laptop, just blow out all the air vents.
  7. Posts : 513
       #16
    Thank you for the reply.
  8. Posts : 19
    Windows 7 Ulitmate 64 bit
       #17
    So this test is only for artifacts and temp, right?
    Hwo di I recognize an artifact? Because I think (not completely sure) that I saw some gliches or errors or something like that on the lower right corner of the screen, but they were there only for a fragment of a second, so I couldn't take a good look at them. Does this mean that my test failed?
    Does it matter if post-FX is on or off by the way?
  9. Posts : 13,354
       #18
    An artifact is a glitch in the display; if you're unsure about it, snap a picture with a camera and upload it here.
    I'm not familiar with the Post-FX option; I'll have to research that. It certainly won't hurt though.
  10. Posts : 19
       #19
    The glitches was there, that's for sure... But only for a very short time. I don't think that I could make a video by the way, because my computer crashed during the tests. However it didn't crashed with my old card...
