Windows 7: Video Card - Stress Test with Furmark
How to Stress Test a Video Card with Furmark
Published by Jonathan_King
28 Jul 2010
1. Download Furmark from the link below.
FurMark: VGA Stress Test, Graphics Card and GPU Stability Test, Burn-in Test, OpenGL Benchmark and GPU Temperature | oZone3D.Net
2. Run the .exe file, and follow the installer choosing the default values. When done, start Furmark.
3. Select your resolution from the drop-down menu, and enable the following:
  • Burn-in
  • Xtreme burn-in
  • Post FX
4. Click "Settings", and select "Log GPU temperature". Press OK when done.
5. Press "BURN-IN test", and the test will start.
6. Watch for artifacts on the screen, and keep an eye on the temperature log. If you see artifacts, or the temperature levels out, stop the test.
31 Jul 2010   #1
Dave76
Nice tutorial, thanks Jon.
31 Jul 2010   #2
Jonathan_King
Windows 7 Professional x64
Thanks Dave.
08 Aug 2010   #3
CarlTR6
Windows 7 Ultimate 32 bit
Another excellent tutorial. You do awesome work, Jonathan.
22 Jan 2011   #4
Shaunie
Windows 7 Premium 64bit
Agree with the rest, Great tutorial.
Im new but you do you some great work.
-Shaun
22 Jan 2011   #5
Jonathan_King
Hello Shaun, and welcome!
Thanks for the comment, see you around!
04 Mar 2011   #6
jeffrkim
Windows 7 Ultimate 64bit
I am running test right now... but It seems fine so far: reaching Frames of 20000 @ 87'C. Do I have to just keep doing it until it reaches crash...? Not sure what to do from here..haha
05 Mar 2011   #7
Jonathan_King
Run it until the temperatures stop increasing; usually less than ten minutes, If you don't see any artifacts or distortion on the screen, consider the test passed.
04 Apr 2011   #8
IMAyNeed
Windows 7 Ultimate 64-bit
I ran the test for half an hour. It reached 100 C. No artifacts. So, the result is passed?
04 Apr 2011   #9
Jonathan_King
Passed, yes; problem identified, perhaps. 100C is quite high, even for a GPU. nVidia GPUs can supposedly reach 105C safely, but reports have temperatures in the lower 90s causing problems as well.
I'd say work on bringing those temps down; use a can of air to blow out heat sinks, fans, and air vents.
furmark test picture looks different? bad gpu?
I was doing a furmark test and noticed that the picture of the furmark test looks different than the ones pictured on google, youtube.. http://i.imgur.com/EW0dLOT.jpg this is a picture found on google, see the difference? google img pic bellow VV ...
Graphic Cards
program to stress test a video card?
I am wondering about a hd2600pro if it might be bad. After a while of playing 1080p streaming video it sometimes pixelates, smears, multiple images, etc... That will start in a small area and rapidly spread across the whole screen. If you stop playing the video and restart, it is ok for a...
Graphic Cards
CPU - Stress Test Using IntelBurnTest
Test your CPU Stability with IntelBurnTest Stress-testing is an important step when adding new hardware to a system, or over-clocking individual components of a system over-and-above their stock settings. In particular, components that generate significant heat within the system require careful...
Tutorials
Interpreting Furmark test?
The card is MSI 6770, less than a year old. How do you guys think of the results (720p Furmark burn-in , MSAA off)...if at all I did it right:-
Graphic Cards
How can I test video card ram?
Hi there. Im wondering if there is any way to test your ram on the gfx card in Windows 7. Or if there is any software that does this?
Performance & Maintenance
Stress Test
Hey I was running some tests on my computer to see the Min-Max temperature , so i wanted a good program that stresses HD, Ram, GPU and CPU. Just like ORTHOS ( But orthos only stresses CPU And RAM ). Oh, and is it possible to Undervolt GPU's? ( I think it is a dumb question, but..). And...
