Windows 7: Driver Verifier - Enable and Disable
07 Feb 2011   #10
3TnT
Windows 7 64 bit
How many time should I let it run ?
I'll only see a popup if a get an error ?
07 Feb 2011   #11
Jonathan_King
Windows 7 Professional x64
Let it run for maybe 24 hours, while using your computer normally. If it finds an error, you will get a BSOD, which should be uploaded for analysis.
19 Jul 2011   #12
Dave76
Nice tutorial Jon, will help many with this, bookmarked.
30 Mar 2012   #13
efcs
windows 7 ultimate 64 bit
When I did verified /query it returns date time and no drivers verified message. Ideas?
30 Mar 2012   #14
Jonathan_King
Quote   Quote: Originally Posted by efcs View Post
Sounds like the Verifier settings were never saved. Did you reboot after enabling Driver Verifier?
30 Mar 2012   #15
efcs
I did restart
31 Mar 2012   #16
Jonathan_King
You might just give it another try. Did you see the "You must restart your computer to save changes" message?
31 Mar 2012   #17
efcs
I did see the message yes and restarted again...no change
31 Mar 2012   #18
Jonathan_King
I'm reading your other thread now; are you verifying any drivers other than the NIC one? If that's the only driver you're trying to verify, then I might be tempted to suspect the two issues are the same.
17 Apr 2012   #19
Influx
Win7 Ultimate x64 SP1 / WCP x64 / Ubuntu 11 x64
Hello Jonathan,
Should this be run in Safe Mode?
Multiple BSOD. Driver Verifier Driver caught a driver corrupting
I have had BSOD for a while and being super busy I did not have time to look at it and get it fixed. Well Being a computer guy I assumed I could fix it myself. But with tons of research and trying to use every guide I can find I decided to try here(probably should have came here first). Today I...
BSOD Help and Support
Turbo Boost UI Monitor Driver. Can I disable, or continue let enable?
Hello all, i'm as you can tell a new user to this website, registering at X time today. The reason I started this thread is that I needed some help on a particular driver component that I just don't know how to deal with, lately I've been disabling certain driver's on my machine for any potential...
Hardware & Devices
Wireless Driver Enable & Disable itself
hi my fellow internet frds.. since i while ago my laptop's wireless been behaving really weird.. the wireless driver will suddenly disable and gone from the network list going into Device manager, it says "this driver is not installed " or sth like that... cant exactly rmb what it said, ...
Network & Sharing
Need Knowledge about Driver Verifier
i want to know about Driver Verifier from Windows 7 , is that for monitoring our Driver, but that will make our system stressing or slow right? that Driver Verifier will Damaged our Hardware or our OS System ? Thanks :D:D Regards sle3pingz :cool:
Drivers
BSOD after driver verifier
Plz check, thanks for more infos.... It's ntoskrnl.exe Searching forum and no proper solution. Startup repair doesn't help - can't fix the problem sfc /scann... no errors chkdsk /r ... no errors
