Driver Verifier - Enable and Disable
How to Enable or Disable Driver Verifier in Windows 7
Contents
Driver Verifier runs in the background, "testing" drivers for bugs. If it finds one, a Blue Screen of Death (BSOD) will result; the corresponding dump file will hopefully show the faulty driver.
OPTION ONE
To Enable Driver Verifier
1. Start typing verifier.exe into the start menu, and open Verifier.
2. Select "Create custom settings (for code developers)", and hit Next.
3. Make sure Standard settings, Force pending I/O requests, and IRP Logging are selected, and hit Next.
4. Select "Select driver names From a list", and hit Next.
5. Click on "Provider" at the top to sort the list by manufacturer; select all drivers not provided by Microsoft Corporation.
6. Press Next, and OK to the resulting window.
After a reboot, driver verifier should be enabled. Use your computer as you normally would, although expect frequent BSODs if there are driver issues. If the system doesn't crash after 24 hours, disable driver verifier.
OPTION TWO
To Disable Driver Verifier
2. Select "Delete existing settings"
If you cannot get into Windows to turn off Verifier, try using Safe Mode.
Hello Jonathan,
Should this be run in Safe Mode?
You can enable Driver Verifier from Safe Mode, but it will not actually run in Safe Mode. Thus, if Driver Verifier is preventing system bootup, you can boot into Safe Mode and disable it. To actually test the drivers, reboot into Normal Mode.
Windows 7 Professional x64Intel i7 2600K OC'd @ 4620 MHz16GB GSkill Sniper 2133 Mhz (4x4GB)EVGA GeForce GTX 480 SuperClocked+
Asus P8Z68-V Pro
2x Acer S273HLbmii 27"
2 x 1920x1080
64GB Crucial M4 SSD
Storage: Hitachi 1TB 5400RPM, Samsung 1.5TB 5400RPM
Corsair HW Series 750w (modular)
Cooler Master HAF 932 Advanced Blue Edition
CM Hyper 212+ CPU cooler, 3x 230mm + 1x 140mm case fans
Logitech MK320 (wireless)
30 Mb/s : 2 Mb/s
Hello Jonathan,
I did hear someone say that it's meant to be run on safe mode. Thanks for clarifying things up Jonathan.
Win7 Ultimate x64 SP1 / WCP x64 / Ubuntu 11 x64
You might consider to add any driver with 'dump' as a prefix to Option one #5, for example; dump_dumpfve.sys and dump_iastor.sys. these should be unchecked also.
They are drivers created to provide disk access during crash dump file generation.
Windows 7 Ult x64 - SP1/ Windows 8 Pro x64Intel Core i5-3570K 4.6GHz8GB (2X4GB) DDR3 1600 Corsair Vengeance CL8 1.5vSapphire HD 7770 Vapor-X OC 1GB DDR5
76~2.0
Gigabyte GA-Z77X UD3H, f18
Onboard VIA VT2021
22" LCD Dell
Samsung 840Pro 128GB SSD,
Corsair HX650W
Cooler Master Storm Scout
Logitech Wave
CM Sentinel
Dismal
Opera Next
Desktop: eSATA ports,
External WD USB 500GB
Wow thanks for the info, I tought I wasnt doing anything wrong.
Windows 7 Home Premium SP1 32 bitAMD Athlon 64 X2 Dual Core 5200+ @ 2.71 GHz2GB DDR2 RAM @ 3** MHz (2 Sticks of 1 GB each...ECS Nvidia GeForce 9800 GT Green Edition 1GB ...
HP Pavilion a6532f
MCP61PM-HM (Nettle3)
2GB DDR2 RAM @ 3** MHz (2 Sticks of 1 GB each, SAMSUNG)
ECS Nvidia GeForce 9800 GT Green Edition 1GB DDR3
Integrated Realtek ALC888S Audio
HP w2007
1680*1050
SAMSUNG 500 GB SATA 7200 rpm
CoolerMaster eXtreme Power Plus 600W
Mid Size ATX
Default rear(back) fan pulling air out.
Genius random(cheap) USB keyboard
Microsoft random(cheap) USB Mouse
2 MBPS / ASDL
i've followed all the steps given but i think i ticked dump_dumpfve.sys and dump_iastor.sys.Is it matter?Now i running it for 5 hours already.So should i restart the process?
Windows 7 Home Premium 64bitIntel(R) Core(TM) i5-3210M CPU @ 2.50GHz6.00 GB(1) Intel(R) HD Graphics 4000 (2) NVIDIA GeFo...
Acer
Acer VA40_HC
6.00 GB
(1) Intel(R) HD Graphics 4000 (2) NVIDIA GeForce GT 630M
No, I would leave it running.
If Driver Verifier generates a BSOD and blames dump_dumpfve.sys and/or dump_iastor.sys, then disable them and let it run again.
These two drivers aren't blamed very often, but there isn't any necessity to stress them so they don't need to be included in the testing.
76~2.0
Onboard VIA VT2021
22" LCD Dell
Corsair HX650W
Logitech Wave
CM Sentinel
Dismal
Opera Next
This didn't work for me. I applied all settings as described, it said I needed to restart so I told it "OK" and nothing happened. I manually restarted, and it just booted up normally without any special screen or status report for the verification. i tried it again but nothing happened.
What should I do to try and force this to work?
This didn't work for me. I applied all settings as described, it said I needed to restart so I told it "OK" and nothing happened. I manually restarted, and it just booted up normally without any special screen or status report for the verification... I'm having BSODs though so that could be it.
It's probably working, it just doesn't show anything.
Open a command prompt and enter verifier /query.
Have a look at the authors response to a previous question like yours.
Win 10 Pro x64
Intel I5-2500K @3.3GHz
Asrock P67 Extreme4
EVGA GeForce 750 Ti SC 2GB
auria eq2367
250GB Samsung 850 EVO SSD
1TB WD Blue
1TB Hitachi
SeaSonic X 650W 80 Plus Gold
Corsair Obsidian 750D
Logitech Wireless Mouse M310
Wave Broadband ~ 100 dn 5 up
Edge, IE11, Chrome
Laptop specs: HP g7-1365dx /
RAM: Crucial 8Gb (2x4Gb) /
GFX: AMD Radeon HD 6520G /
OS: Windows 10 Pro x64
i did this and my computer would lock up everytime i started it up windows would briefly start then log off and lock....why is this?
vista 64bit
vista 64bit
I tried to use this and that was impossible because my pc crashed with brief flash of bscreen before Windows even started to load. Had to do recovery in there start screen to get normally in Windows. So this verifier-program seem to be quite hazardous to use.
Windows 7 Pro 64biti2700KGSkill DDR3 2133Mhz 8Gb(2x4Gb)Asus GTX670 DCII
Own build
Windows 7 Pro 64bit
i2700K
ASRock Z77 Extreme4
Asus GTX670 DCII
OCZ Vertex 4 60Gb
Kingston V300 120Gb
2x Samsung F3 1Tb
FSecure
Same thing happened to me. Do you know what might be causing this?
Windows 7 64bit
Windows 7 64bit
hey i just followed your instructions which are very goodbtw :)
what will this do? will it test all the drivers i have selected for problem or what?
64 bit windows 7 home professional SP1intel i5 3570k 3.4ghz quad coreDDR3 16GB 1600MHZASUS AMD R9 270X OC
ASUS P8-Z77-V LX
DDR3 16GB 1600MHZ
ASUS AMD R9 270X OC
SB Audigy
Novatech
1920 - 1080 60HZ
3 X 500G
seagate momentus xt 750
850w
novatech
1 blue led outtake + 1 blue led Intake 1 cpu 1 gpu 1 psu
aula
Mad Cats ( R.A.T 3 )
300 mbps
I tried to use this and that was impossible because my pc crashed before Windows even started to load. Had to Go into safe mode to disable Verifier.exe for my PC to boot into windows Any help please..:(
Windows 7 Ultimate 32 bitIntel(R) Core(TM)2 Quad CPUTotal Virtual Memory 6.00 GB
acer
M3802 MOTHERBOARD G43T-AM 2.0 AM3
Eset Smart Security
IE 11
That's the whole idea: any bad driver will instantly crash your system and generate a minidump file with crash information, if you enabled minidump files to be written to your Windows folder before using verifier. To switch verifier off, simply boot in Safe Mode open verifier again and disable it.
Microsoft Windows 7 Professional 64-Bit 7601 ...Intel(R) Core(TM) i7-3930K CPU @ 3.20 Steppin...Kingston KHX1600C9D3K4/16GX 16 GB DDR3 9-9-9-27AMD FirePro V4900 (FireGL V)
Custom build 01/06/2012, rebuilt 10/24/2014
Microsoft Windows 7 Professional 64-Bit 7601 Multiprocessor Free Service Pack 1
Intel(R) Core(TM) i7-3930K CPU @ 3.20 Stepping 6 Revision C1
ASUSTeK COMPUTER INC. P9X79 BIOS 4608
(1) AMD High Definition Audio Device (2) Realtek High Defini
HP LP2475w
1920 x 1200
(1) ATA SAMSUNG HD204UI SCSI Disk Device
(2) ATA SAMSUNG SSD 830 SCSI Disk Device
CORSAIR HX650W
fractal design DEFINE R4
Noctua NH-D14 SE2011 and 2 x NF-A14 PWM
FILCO Majestouch 2 Ninja
IE11
TP-LINK 150Mbps-Wireless-N-PCI-Adapter TL-WN751ND
Ran the verifier and had to restart manually. Upon restart Windows didn't start normally and had to perform a Repair and then a System Restore. Any ideas? :shock:
windows 7 Home Premium 64 bitIntel i3-4130Corsair Vengeance 8GB 1600onboard
Intel i3-4130
Gigabyte GA-Z87X-UD4H
onboard
WD800JD
Firefox 28.0
In the end, in my case, it was bad memory...
HP LP2475w
1920 x 1200
CORSAIR HX650W
IE11
I put off the memory test since it's new but there's still the possibility it may be bad. I'll run MEMTEST to check. Thanx for the info.
Intel i3-4130
onboard
WD800JD
Firefox 28.0
Hi, I followed the instructions but the computer was unable to restart normally.
I started in Safe Mode and changed the settings back
Not sure where to go from here any advice appreciated
a copy of the Whocrashed report as follows
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Fri 08/08/2014 09:40:31 GMT your computer crashed
crash dump file: C:\Windows\Minidump\080814-16754-01.dmp
This was probably caused by the following module: netbt.sys (netbt+0x24D30)
Bugcheck code: 0xC9 (0xC, 0xFFFFFFFF8891B380, 0xFFFFFFFF9D6B8F68, 0x0)
Error: DRIVER_VERIFIER_IOMANAGER_VIOLATION
file path: C:\Windows\system32\drivers\netbt.sys
product: Microsoft? Windows? Operating System
company: Microsoft Corporation
description: MBT Transport driver
Bug check description: This is the bug check code for all Driver Verifier
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
windows 7 x32 ultimate2048MB RAM
HP
2048MB RAM
Avast!
Hello Mike, and welcome to Seven Forums.
See if you may be able to do a system restore (in safe mode or at boot) using a restore point dated before this happened to hopefully undo and fix it for you.
Hope this helps for now, :)
Hi Brink, thanks for your response, I am still working on the problem ( when I do not need the computer )
My next move was to decrease the amount of drivers selected to just the first 10 and the result was the same
Next time I shall limit it to the first 5:geek:
Iam also checking/updating drivers
HP
2048MB RAM
Avast!
