Driver Verifier - Enable and Disable
Page 1 of 5 123 ... LastLast
    How to Enable or Disable Driver Verifier in Windows 7
    Contents
    Driver Verifier runs in the background, "testing" drivers for bugs. If it finds one, a Blue Screen of Death (BSOD) will result; the corresponding dump file will hopefully show the faulty driver.
    OPTION ONE
    To Enable Driver Verifier
    1. Start typing verifier.exe into the start menu, and open Verifier.
    2. Select "Create custom settings (for code developers)", and hit Next.
    3. Make sure Standard settings, Force pending I/O requests, and IRP Logging are selected, and hit Next.
    4. Select "Select driver names From a list", and hit Next.
    5. Click on "Provider" at the top to sort the list by manufacturer; select all drivers not provided by Microsoft Corporation.
    6. Press Next, and OK to the resulting window.
    After a reboot, driver verifier should be enabled. Use your computer as you normally would, although expect frequent BSODs if there are driver issues. If the system doesn't crash after 24 hours, disable driver verifier.
    OPTION TWO
    To Disable Driver Verifier
    2. Select "Delete existing settings"
    If you cannot get into Windows to turn off Verifier, try using Safe Mode.
  1. Posts : 712
    Windows 7 x64, Windows XP SP3, Fedora
    Nicely written!
  2. Posts : 11,990
    Windows 7 Ultimate 32 bit
    Very well done, Jonathan. Good clear instructions with illustrations.
  3. Posts : 11,408
    ME/XP/Vista/Win7
    Nice one, JK.
  4. Posts : 17,322
    Win 10 Pro x64
    Good one JK, I didn't know that was there.
  5. Posts : 13,354
    Windows 7 Professional x64
    Thanks guys. :)
  6. Posts : 301
    7 Ultimate x64 SP1
    This didn't work for me. I applied all settings as described, it said I needed to restart so I told it "OK" and nothing happened. I manually restarted, and it just booted up normally without any special screen or status report for the verification... I'm having BSODs though so that could be it.
    What should I do to try and force this to work?
  7. Posts : 13,354
    It's probably working, it just doesn't show anything.
    Open a command prompt and enter verifier /query.
  8. Posts : 14
    HI JK! UMMM should i verify this drivers too? )= kinda need some help here x.x
    Driver Verifier - Enable and Disable Attached Files
  9. Posts : 13,354
    Yep, you want everything that doesn't say Microsoft, Unknown, or Macrovision.
