Windows 7: RAM - Test with Memtest86+
How to Test and Diagnose RAM Issues with Memtest86+
Published by Jonathan_King
20 Aug 2010
Contents
Part 1: Preparing the Media
Method 1: With a USB Memory Stick
1. Download the latest version of the "Auto-installer for USB Key (Win 9x/2k/xp/7)" from this link: Memtest86+ - Advanced Memory Diagnostic Tool
2. Plug in an empty USB key drive. Size is no concern, as the actual files take up 180 KB of space.
3. Go into the .zip folder you downloaded, and double-click on the .exe file inside.
4. Follow the setup utility. To reduce the risk of problems, it is advised to format the drive.
Method 2: With a CD
1. Download the latest version of the "Precompiled Boot ISO (.zip) from this link: Memtest86+ - Advanced Memory Diagnostic Tool
You want the "Precompiled Boot ISO (.zip)".
2. Open the .zip file you downloaded, and then drag the .ISO file inside onto the Desktop.
3. Right-click on the ISO, and select Open with>Windows Disc Image Burner.
4. Insert a blank CD into the CD drive, and make sure the correct Disc burner is selected.
5. Click on "Burn".
Now the CD is ready to use.
Part 2: Testing
1. With the CD in the drive, or the USB key inserted, reboot your computer. If Memtest does not automatically boot, go into the BIOS and change the CD drive or USB drive to be the first to boot.
2. Memtest will immediately start testing as soon as it boots. No attendance is needed.
3. Let it run until at least 8 passes are completed, or errors are found (whichever comes first). The longer you run it, the better.
Seven passes will take several hours, depending on your amount of RAM. It is advised to leave it running overnight.
Part 3: If You Have Errors:
The goal is to test all the RAM sticks and all the motherboard slots.
Check your motherboard manual to ensure the RAM sticks are in the recommended motherboard slots. Some motherboards have very specific slots required for the number of RAM sticks installed.
If you get errors, stop the test and continue with the next step.
1. Remove all but one stick of RAM from your computer (this will be RAM stick #1), and run Memtest86 again, for 7 passes.
Be sure to note the RAM stick, use a piece of tape with a number, and note the motherboard slot.
If this stick passes the test then go to step #3.
2. If RAM stick #1 has errors, repeat the test with RAM stick #2 in the same motherboard slot.
If RAM stick #2 passes, this indicates that RAM stick #1 may be bad. If you want to be absolutely sure, re-test RAM stick #1 in another known good slot.
If RAM stick #2 has errors, this indicates another possible bad RAM stick, a possible motherboard slot failure or inadequate settings.
3. Test the next stick of RAM (stick #2) in the next motherboard slot.
If this RAM stick has errors repeat step #2 using a known good stick if possible, or another stick.
If this RAM stick has no errors and both sticks failed in slot#1, test RAM stick #1 in this slot.
4. If you find a stick that passes the test, test it in all the other motherboard slots.
If Part 2 testing shows errors, and all tests in Part 3 show errors, you will need to test the RAM sticks in another computer and/or test other RAM in your computer to identify the problem.
In this way, you can identify whether it is a bad stick of RAM, a bad motherboard, or incompatibility between the sticks.
Thanks to Dave76 for his assistance in this part.
Note   Note
While the same concept is completely valid for other operating systems, a different image burner will be needed. A good free program is ImgBurn.
20 Aug 2010   #1
richc46
An excellent tutorial for all those that want to test their RAM. In addition, the BSOD Squad can give this tutorial to an OP with a BSOD that may be related to memory. Bravo.
20 Aug 2010   #2
Jonathan_King
Windows 7 Professional x64
Thanks.
Now we don't all have to use my Memtest canned speech.
20 Aug 2010   #3
Wishmaster
Excellent!
20 Aug 2010   #4
CarlTR6
Windows 7 Ultimate 32 bit
Superb, Jon; very well done. Thank you much. Tried to rep; but I gotta spread some around first.
20 Aug 2010   #5
jcgriff2
Windows 7 - Vista
Great job, Jonathan !!
20 Aug 2010   #6
derekimo
Nice work JK.
20 Aug 2010   #7
richc46
Quote   Quote: Originally Posted by derekimo View Post
Nice work JK.
You have no idea, how good. For the BSOD Squad its a gift.
20 Aug 2010   #8
derekimo
Quote   Quote: Originally Posted by richc46 View Post
Nice work JK.
I've seen quite a few posts there, so I can see this being a gift!
20 Aug 2010   #9
sygnus21
Windows 10 Pro
About time
We needed a tut like this one here. The one I used to link to was rather long and technical. Good job
+1
Memtest86+
How long should memtest run?
Software
When Memtest86 and WMD test fail?
I'm helping a friend with a Dell Dimension 2350 1gig Ram Pentium 4. His XP was virus-riddled and hung horribly even after clean up with SysFiles repaired. HD cleared diagnostics, wiped HD, ran memtest86 which shut down test both times at 3% first pass. Now in Win7 having similar problems with...
Hardware & Devices
memtest86+ v4.10
when running memtest are a few errors ok? or am i going for 0 errors no matter what? does 5 errors mean that one of the sticks of ram is bad? or does it have to be like 100's of errors? i should narrow it down by slot/stick right? (use known good slot with each stick, then use known good stick...
Hardware & Devices
Ran memtest86
I've gotten recent BSOD's, first i took my computer to the store and my graphics card was messed up. That was some months ago and i got a new graphics card. The BSOD's still occured though and last night I ran memtest86 for 4 passes and? it had 40 errors. Is it pretty much safe to assume that...
BSOD Help and Support
Anyone with a HD 5850 run a test on Passmark performance test?
Hi Guys, Just recently got a Powercolor HD 5850 gpu , and have ran a test on the latest Passmark performance test benchmarking software. It seems about right on the 3d score with around 2200 But the 2d score is very low at around 320 Is this normal?
Graphic Cards
Memtest86+ 4.00
9/22/09 - memtest86+ 4.00 source..
Software
