Control Panel - Add or Remove from Desktop Context Menu
    How to Add or Remove "Control Panel" from Desktop Context Menu in Windows
    This will show you how to add or remove Control Panel from the desktop right click context menu for all users on the computer in Windows 7 and Windows 8.
    You will only be able to do this while logged in as an administrator.
    EXAMPLE: Desktop Context Menu and Control Panel
    Control Panel - Add or Remove from Desktop Context Menu-cp_category_view.jpg
    Here's How:
    1. Do step 2 or 3 below for what you would like to do.
    2. To Add "Control Panel" to Desktop Context Menu
    A) Click/tap on the Download button below to download the file below, and go to step 4 below.
    Add_Control_Panel_to_Desktop_Context_Menu.reg
    3. To Remove "Control Panel" from Desktop Context Menu
    Remove_Control_Panel_from_Desktop_Context_Menu.reg
    4. Save the REG file to your desktop.
    5. Double click/tap on the REG file to merge it.
    6. If prompted, double click/tap on Run, Yes (UAC), Yes, and OK to approve the merge.
    7. When done, you can delete the downloaded .reg file if you like.
    8. Right click on your desktop to see the change.
  1. Posts : 20
    Another !!!! omg is this a hobby of yours ? Ty again soon all my icons will be gone and I will have empty docks rofl
  2. Posts : 8,679
    Nice one Shawn! As usual...
  3. Posts : 72,052
    Thank you.
