Office 2010 - Perform Repairs
    How To Perform Repairs in Microsoft Office 2010
    There are two methods in Office® 2010 to perform repairs and diagnostics - manually and automatically. These methods are described below
    OPTION ONE
    Manually Run Repairs
    1. Close all the Office® 2010 applications.
    2. Open Windows® Control Panel from the Start menu and double-click Add or Remove Programs (Windows® XP, Windows® Server 2003) or Programs and Features (Window Vista®, Windows® 7, Windows® Server 2008).
    3. On the list of programs, select Microsoft Office 2010, and click Change. For Window Vista®, Windows® 7, Windows® Server 2008, you would right-click on the program select Change.
    4. On the change screen, select Repair, and click Continue.
    5. The repair process will begin. This process may take several minutes.
    6. When the repair is complete, the following dialog box will appear. Click Close, then reboot the computer to complete the process.
    OPTION TWO
    Automatic Diagnostic
    You can configure Office to periodically download a diagnostic utility from Microsoft® to check for system problems that may affect Office® 2010. Follow the steps below to set this up:
    1. From any Microsoft® Office® 2010 application, click the File tab, then click Options.
    2. On the Options screen, select Trust Center, then click Trust Center Settings.
    3. From the Trust Center screen, select Privacy Options on the left.
    4. Under the Privacy Options section on the right, check the box for Download a file periodically that helps determine system problems.
    5. Click OK to save these settings.
    Captain
  1. Posts : 8,476
    Windows® 8 Pro (64-bit)
    That's great Shyam.
  2. Posts : 12,177
    Another great tutorial, excellent reference, thanks.
  3. Posts : 17,322
    Win 10 Pro x64
    Nice work Shyam, well done!
  4. Posts : 11,990
    Windows 7 Ultimate 32 bit
    Nice work, Shyam. I will probably make use of this when I upgrade.
  5. Posts : 4,772
    Thanks guys !
  6. Posts : 544
    Windows 10 Home, 64 bit
    I was just looking for this the other day! Nice tutorial. I have a few questions, if I may:
    What is the file that is periodically downloaded? What does it actually do, and how does it work? Also, can the file be downloaded manually, and can the diagnostic it performs be started manually?
    Thanks.
    Attached Thumbnails Attached Thumbnails Office 2010 - Perform Repairs-download.png
  7. Posts : 4,772
    Hello there,
    Honestly I'm not sure what it downloads periodically but enabling that option try to repair Outlook automatically instead of we manually initiating it. Unlike other Office versions we can't run the Diagnostic manually. Microsoft removed that option which I'm not very happy about
  8. Posts : 544
    Agreed. I did a repair installation when MS Word would not retain a setting I had placed. That seems to have fixed the problem. Still, I had checked downloading the diagnostic, but it obviously did not catch this problem. So I was wondering what this mysterious utility is and if it can be run manually.
