SSD Alignment
Page 11 of 14 FirstFirst ... 910111213 ... LastLast
  1. Posts : 126
    Windows 7 Professional x64
       #100
    You say align it. Will it be alligned if I do diskpart? Sorry, I'm brand new to the world of SSD.
  2. Posts : 24,479
    Windows 7 Ultimate X64 SP1
       #101
    Yes, it's the 5th line in the process:
    Create partition primary align=1024
  3. Posts : 12,012
       #102
    You align it manually after entering diskpart:
    Enter diskpart from a command prompt; these would be the commands:
    Diskpart (to enter diskpart)
    List disk (to get diskpart to show you a list of disks it sees; you should have only the SSD connected)
    Select disk n (where n is the number that diskpart says applies to the SSD; normally it's 0; might be 1)
    Clean (wipes the drive clean if anything is on it)
    Create partition primary align=1024 (this creates and aligns a primary partition)
    Format fs=ntfs quick (this formats the SSD with NTFS file system)
    Active (this makes the partition active)
    Exit
  4. whs
       #103
    Thanks guys, you are so helpful.
  5. Posts : 126
       #104
    Exit
    After this, will the SSD be ready to add the Windows 7 image?
  6. whs
       #105
    Yes
  7. Posts : 126
       #106
    I was hoping to image my ssd (tomorrow when everything arrives) but I'm reading that because my PC was set to raid and not AHCI when 7 was installed I won't be able to do anything but a clean install. Is this correct, or is there something I can do to make it work?
  8. whs
       #107
    Nah, that has nothing to do with it. Leave it set to Raid.
  9. Posts : 126
       #108
    Thanks for all your help. I may have more questions.
  10. whs
       #109
    Any time.
