Share with - Restore when Missing in Context Menu
    How to Add or Remove "Share with" Context Menu Item in Windows 7 and Windows 8
    This tutorial will show you how to add or remove the Share with context menu item when you right click on a file, folder, drive, or library in Windows 7 and Windows 8.
    EXAMPLE: "Share with" in the Context Menu
    OPTION ONE
    To Restore "Share with" Context Menu Item
    1. Open Folder Options in Windows 7 or Windows 8, check the Use Sharing Wizard box, and click/tap on OK. (see screenshot below)
    NOTE: This option has to be checked to have Share with in the context menu for files.
    2. If the above doesn't help, then click/tap on the Download button below to download the REG file below.
    NOTE: You must be logged in as an administrator to be able to do this step.
    Restore_Share_with_to_Context_Menu.reg
    Download
    A) Save the .reg file to your desktop.
    B) Double click/tap on the downloaded .reg file to merge it.
    C) If prompted, click/tap on Run, Yes (UAC), Yes, and OK to approve the merge.
    D) When finished, you can delete the downloaded .reg file if you like.
    3. The missing Share with context menu item should now be restored.
    OPTION TWO
    To Remove "Share with" Context Menu Item
    1. Open Folder Options in Windows 7 or Windows 8, uncheck the Use Sharing Wizard box, and click/tap on OK. (see screenshot below)
    2. If the above doesn't help, then click on the Download button below to download the REG file below.
    Remove_Share_with_to_Context_Menu.reg
    Download
    3. The Share with context menu item should now be removed.
  1. Posts : 25
    Windows 7 Professional x86
    great work!
  2. Posts : 72,051
    Thank you Kyle. :)
  3. Posts : 4
    big ups, major props, much gratitude
  4. Posts : 960
    Windows 7 Ultimate SP1 - 64 Bit
    Title - How to Romove or Restore "Share with" Context Menu Item in Windows 7
    Remove.
  5. Posts : 72,051
    LOL, oops. Must be that new type of remove. Fixed
  6. Posts : 23
    Win 7 Home Prem 64
    Brink....you're a bloody genius. It's taken me two weeks to find this solution, but it works! Yeahhhhh!!!!
  7. Posts : 72,051
    That's great news Chris. I'm happy that it was able to help. :)
  8. Posts : 260
    Windows 7 Ultimate 64bit
    Hi, I've looked everywhere and redirected here.
    I followed instructions to remove the "Share with" option from windows command(menu) bar (next to organize, and burn, and new folder...)
    After taking ownership of HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\CommandStore\shell\Windows.Sha re, I changed 'Canonical Name' Value from
    {E39543A3-079B-4BFB-A498-4777984155CA}
    to
    "" (empty)
    restart removed the (Share With) button (I don't use homegroup, I use old school network shares on the sharing tab)
    I also lost my sharing tab (right click folder, properties, there's usually a sharing tab, where you can create hidden network shares)
    I restored the reg backup, and the share with button is back.. but the sharing tab isn't. Makes me think it was already missing, but I don't know how to get it back
    Can anyone help? I've checked and the protected ntshrui.dll is in system32
    HELP!!?
  9. Posts : 260
    Fixed! Shellexview had the sharing context menu option disabled. Previously this only disabled the "share with" context menu, but after enabling it, the sharing tab is restored (along with the unwanted share with context menu item, and still the original offender, the share with button on the nav bar).
    Tempted to give up! Quitting while .. no longer behind
