Windows 7: Disk Defragmenter - Open and Use
11 Jul 2012   #40
Brink
64-bit Windows 10 Pro
Yep, I fully understand your question.
11 Jul 2012   #41
sle3pingz
Quote   Quote: Originally Posted by Brink View Post
Thanks , Maybe the simple said is "Plugged in the charger / charging when middle of defragging / Process Defragging"
16 Aug 2012   #42
sle3pingz
Brink , i want ask again, if we often do defrag maybe like a week once, that will damaged the Harddisk / decrease Harddisk Lifespan? simple said is "if often do disk defrag it will damaged the Harddisk?" Thanks
16 Aug 2012   #43
Brink
Hello sle3pingz,
No, you will be fine.
19 Jan 2013   #44
Juxxize
Microsoft Windows 7 Home Premium 64-bit SP1
er I'm a little puzzled some people say don't defrag your recovery drive/ recovery partition ( D in my HP laptop ) and some say it's OK , look how much mine is fragmented Disk Defragmenter - Open and Use-defragresults.png
what should I do , is it OK to defrag my recovery drive ?
and just to add my C drive is fine I defrag that when ever it's needed but I've been fear-ful of de-fragging my recovery drive D
19 Jan 2013   #45
Brink
Hello Juxxize,
Usually it's not recommended to defrag the recovery partition. I would say let it be since if anything went wrong with it, you would no longer be able to do a factory recovery of Windows with it.
It's not going to hurt anything since you are not supposed to be using this partition for anything other that doing a factory recovery as needed.
If you have not already, I would also recommend to create a set of recovery discs or save a recovery image to a USB flash drive as a backup.
HP PCs - Creating Recovery Discs or Saving a Recovery Image to a USB Flash Drive (Windows 7) - c01867124 - HP Business Support Center
19 Jan 2013   #46
Juxxize
Thank-you Brink, i have a back-up and system image i made on an external hard-drive ( although it's about time i did a fresh back-up ) and i made a system repair disk a while back although i may make another just to be on the safe side . I've not heard of the Recovery Disc Creation/ Recovery Media Creation which is the second option mentioned in the page of the link you posted so i will look into that but having a repair, backup and system image i made along with the back-up i should be OK. It is odd my recovery drive has got so fragmented isn't it when it isn't used. I factory reset my laptop a few months ago but apart from that it's never used so it's odd indeed, thanks again.
Disk Defragmenter Schedule- Turn On or Off
How to Turn the Windows 7 Disk Defragmenter Schedule On or Off This will show you how to turn the Disk Defragmenter schedule on or off to allow it to run automatically in Windows 7 or not. Disk Defragmenter is set to run on a automatic schedule by default in Windows 7. The Disk Deframenter...
Tutorials
Windows Disk Defragmenter
Why does the Defragmenter analysis start at 34%?
Performance & Maintenance
Disk Defragmenter stuck at 1%
As the title says, it is stuck and has been for the last several weeks. I run the Defragmenter once a week. My system seems to be running fine, so please any help and info about it would be great. I am running Windows 7 Home Premium
Disk Defragmenter won't defragment a certian disk.
So I have a Windows 7 Toshiba laptop and I use the default defragmenter to help clean my computer. There are 2 disks that it can defragment: (C: ) and System Beside each of them shows the last time they were last looked at and how fragmented they are. It says that 2% of System is fragmented,...
Disk Defragmenter Stuck
Hello just a quick question. When I run Disk Defragment it all goes well up until Pass 2: 0% Relocated. It just stops there and will not continue, even for an hour or so. Any ideas?
disk defragmenter
Hi folks, When I try to run the defrag from the CMD (defrag C: /U) I get an error message that says: The disk defragmenter could not start because you have insufficient priveleges to perfrom this operation. (0x89000024) I have Administrative priveleges. Do I need to switch to a root...
