Disk Defragmenter - Open and Use
Page 5 of 5 FirstFirst ... 345
  1. Posts : 72,055
       #40
    Yep, I fully understand your question.
  2. Posts : 225
    Thanks , Maybe the simple said is "Plugged in the charger / charging when middle of defragging / Process Defragging"
  3. Posts : 225
    Brink , i want ask again, if we often do defrag maybe like a week once, that will damaged the Harddisk / decrease Harddisk Lifespan? simple said is "if often do disk defrag it will damaged the Harddisk?" Thanks :)
  4. Posts : 72,055
       #43
    Hello sle3pingz,
    No, you will be fine. :)
  5. Posts : 66
    Microsoft Windows 7 Home Premium 64-bit SP1
       #44
    er I'm a little puzzled some people say don't defrag your recovery drive/ recovery partition ( D in my HP laptop ) and some say it's OK , look how much mine is fragmented Disk Defragmenter - Open and Use-defragresults.png
    what should I do , is it OK to defrag my recovery drive ?
    and just to add my C drive is fine I defrag that when ever it's needed but I've been fear-ful of de-fragging my recovery drive D
  6. Posts : 72,055
       #45
    Hello Juxxize,
    Usually it's not recommended to defrag the recovery partition. I would say let it be since if anything went wrong with it, you would no longer be able to do a factory recovery of Windows with it.
    It's not going to hurt anything since you are not supposed to be using this partition for anything other that doing a factory recovery as needed.
    If you have not already, I would also recommend to create a set of recovery discs or save a recovery image to a USB flash drive as a backup.
    Hope this helps, :)
  7. Posts : 66
       #46
    Thank-you Brink, i have a back-up and system image i made on an external hard-drive ( although it's about time i did a fresh back-up ) and i made a system repair disk a while back although i may make another just to be on the safe side . I've not heard of the Recovery Disc Creation/ Recovery Media Creation which is the second option mentioned in the page of the link you posted so i will look into that but having a repair, backup and system image i made along with the back-up i should be OK. It is odd my recovery drive has got so fragmented isn't it when it isn't used. I factory reset my laptop a few months ago but apart from that it's never used so it's odd indeed, thanks again.
