Fonts - Change
Page 10 of 16 FirstFirst ... 89101112 ... LastLast
  1. Posts : 5
    Windows 7 x86 Ultimate
       #90
    How do i change buttons' and other controls' font size?
  2. Posts : 72,046
       #91
    Hello Fixer, and welcome to Seven Forums.
    To change the font size of an item not listed in OPTION ONE, you could use a 3rd party skinning program to make it easy to do so.
  3. Posts : 5
       #92
    Can you give some examples? Do you mean software like Win7 Style Builder?
  4. Posts : 9,537
    Here's a free software program to take a look at.
    Layouts - Add FREE Customized Layouts, Generators, Graphics and Bling to Your Page! | skin free
  5. Posts : 168
    Windows 10 Home 64b
       #94
    Does this tutorial apply if i want to make windows 7 use one type of font only and delete the rest? i remember that last year i removed most of the fonts and only let some like Webdings, Times New Roman, Gothics one and then the text of some dialog boxes were not completely visible.
  6. Posts : 72,046
       #95
    Hello LM,
    Yes, you could use OPTION THREE to set everything to use one font, then manually delete the others. I would recommend to either backup the other fonts or leave the deleted fonts in the Recycle Bin for a while to make sure that there wasn't one still being used though. This way you could just easily restore it.
  7. Posts : 168
    Windows 10 Home 64b
       #96
    I backed up the registry and the font folder, plus and image with windows backup just in case, i will restart and test. Last year i did this except the option 3 that i haven't seen it before.
  8. Posts : 72,046
       #97
    Yeah, I'm always updating and adding to the tutorials. :)
    Please let us know how it went for you.
  9. Posts : 5
       #98
    What? How is this software even connected with Windows and fonts?
  10. Posts : 9,537
    My mistake!
    I thought you were talking about 3rd party software skins...
