Windows 7: Run as Administrator
07 Oct 2012   #80
bigfattty5
windows Xp Home Edition
replyed
run as is where you can allow the limited account to run it a the admin rights without changing the limited account status to administrator
hope to get approved
cheers tylerxxx
12 Oct 2012   #81
eferris
Win 7 Pro 32/64
Hey all,
So following the regedit way, I'm trying to get OpenVPN to run as admin automatically. The entry changes the .exe to run as admin under compatibility but it does not work as needed.
When running it I get - The requested operation requires elevation (this is to change some routing through windows to properly connect to our network).
When I right click run as admin it works properly. Also works as needed when I physically add the run as admin through the properties -> compatibility.
Odd yes?
The point of getting it through regedit is I'm going to have the changes done through a .bat script so users in my office just run the script and they don't have to worry about having to right click to run or change the properties of the .exe themselves.
Any ideas?
12 Oct 2012   #82
Brink
64-bit Windows 10 Pro
Hello eferris, and welcome to Seven Forums.
This has happened to another user as well, and the solution was to add the registry entries to both HCU and HKLM locations in the registry. Hopefully it will work for you as well.
(Option 3): Compatibility Mode
12 Oct 2012   #83
eferris
Win 7 Pro 32/64
Quote   Quote: Originally Posted by Brink View Post
That worked! Thank you very much!
12 Oct 2012   #84
Brink
You're most welcome.
27 Oct 2012   #85
ardygtg
win 8 32 bit
it is possible to run all *.exe files as adminstrator, just for once setting
please help, thanks
27 Oct 2012   #86
Brink
Hello Ardy,
Sure. You could enable and log on to the built-in Administrator account. Anything you run in this account will run as administratror (elevated). It's not recommended to do though for security reasons.
Built-in Administrator Account - Enable or Disable
30 May 2013   #87
BrianWa
Windows 7 64 Bit
I want to logon as standard user and run my system board application
as administrator on Windows 7.
Earlier i used the tool Cpau. On Windows 7 i use Runasrob.
Is there a way to do this with Windows dashboard tools?
30 May 2013   #88
Brink
Hello Brian, and welcome to Seven Forums.
You should be able to use the method in the tutorial below to do so. You'll have to use the built-in Administrator account to be able to set the shortcut up.
Elevated Program Shortcut - Create for Standard User
30 May 2013   #89
BrianWa
Windows 7 64 Bit
runas administrator savecred is the way i can go instead of runasrob
great, thank you
I AM the Administrator,UAC is OFF,Yet I need Administrator Permission
Because LIFE is short and precious, it's reasonable to not have to waste time, clicks and energy FIGHTING the most simple of OS tasks: deleting a file or folder. Because it was SO DRAINING to add thousands of extra hoops to my daily work, I now log in as the Administrator and have turned off...
General Discussion
User Administrator Account won't allow Administrator Privilages
Hi, I'm running Win 7 Pro x64 and Office 2007. I installed a Bluetooth transceiver recently and developed a problem when replying to email in Outlook 2007. When I select an email to reply, the email editor pops up with a "Custom UI Runtime Error in Send to Bluetooth." The solution to this issue...
General Discussion
User is both an Administrator, and not an Administrator. Cannot change
An account on my Windows 7 installation cannot have its type changed from an administrator to a user account. I tried to change it using the cmd and I'm getting these messages: >net localgroup administrators AccountName /del System error 1377 has occurred. The specified account name is...
General Discussion
Renaming the administrator account back to Administrator
Hi, I have an Acer laptop which came with one user account, Acer, with the administrator right. When I tried to rename it to Administrator or administrator, I got an messages saying that user name has already existed. How do I rename Acer to Administrator? Thanks.
General Discussion
Administrator without administrator privileges?
I have an administrator account on my laptop, but when I display its properties it says I am a standard user and will not let me change the account type. How can I change my account type to administrator.
General Discussion
Administrator account isn't a 'real' administrator :(
I hope this is the correct forum for this question. I currently have Windows 7 32bit installed on one partition ( D: and I just installed Windows 7 (64bit) on another partition ( C:. I log into Windows 7 64bit using Administrator BUT when I try to do things like move where the...
General Discussion
