Windows 7: System Reserved : Create Using Disk Management
12 Mar 2011   #10
RJ12
I think I have an old System reserved partition. It's one GB and it says is a recovery partition.
I have a screenshot attached. Do I need to name it System Reserved and it will automatically make it the way it needs to be or do I need to do something else?
System Reserved : Create Using Disk Management-disk-management.png
12 Mar 2011   #11
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
Hello.
May I ask you a few questions first?
1) Do you have a set of factory recovery disks?
2) Is it a factory installation of Windows 7?
3) Have you altered the partition structure?
4) Do you have actual Windows 7 installation media?
I believe you could trim down the size of the 'recovery' partition and create an actual System Reserved partition in its place.
12 Mar 2011   #12
NoN
Quote   Quote: Originally Posted by Bare Foot Kid View Post
Hello.
May i ask for myself either?
I do have the questions you asked first but not altered any of the partitions structure. I tried Diskpart cmd to extend this System Reserved partition created at my factory install.
I couldn't extend this partition to the desired 200mb instead of 100mb.
Do you think i can create another system reserved partition like 200Mb then delete my 100Mb (is marked as "active" partition) without messing the install?
Thanks BFK.
12 Mar 2011   #13
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
Quote   Quote: Originally Posted by NoN View Post
I do have the questions you asked first. I tried Diskpart to extend this System Reserved partition created at my factory install.
Do you think i can created another partition like that of 200Mb then delete my 100Mb (is marked as "active" partition) without messing the install?
Thanks BFK.
Hello to you.
Post a snip of Windows 7 disk management for me to see, with a full description of what is what; please.
Note   Note
In the Windows start menu right click computer and click manage, in the left pane of the "Computer Management" window that opens click disk management and post a snip of that.
How to Upload and Post a Screenshot and File in Seven Forums
12 Mar 2011   #14
NoN
This is what i have in Disk Management in that order.
1) Recovery partition
2) my actual C: partition
3) System Reserved partition.
Looks i'm not authorized to extend the System Reserved Part.
System Reserved : Create Using Disk Management-capture.png
12 Mar 2011   #15
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
Have you created the factory recovery disks yet?
12 Mar 2011   #16
NoN
Yes!
I'm asking that because of eventually being able to multi-boot...looks 100mb system reserved is not enough
12 Mar 2011   #17
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
Yes!
The one question I would ask you is, how complicated, how much work do you want to put into this because it is possible.
There are ways using the Partition Wizard Bootable Disk (PWBD) to shrink the left side of C: and add that space to the SysResv to increase it to 200MB and that should be enough for a multi boot.
Have a look at this one though you would need to shrink the C: just enough to get to 200MB for the SysResv.
System Reserved : Create for Dual Boot
There's also this possibility, Method Two if you want to have a go but it's up to you.
Partition / Extended : Logical Drives
It all will be a good bit of work to accomplish successfully.
12 Mar 2011   #18
NoN
Yes!
Thanks BFK, i quick-looked already those.
Now i'll go read that carefully, and make up my mind, after!
Thank for the input!
12 Mar 2011   #19
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
You're welcome, if you decide you want to do it I will be glad to assist you, just let me know.
Changing System Reserved information in Disk Management
Hello all. I have recently done a repair install to fix an issue with Windows Media Player. But before that, I had changed the C drive or partition to active, and have read just now that the system reserved part should be marked active. Can I switch it back to active without anything bad...
General Discussion
Disk management - system reserved
Win 7 Home Premium 64-bit SP1. What is system reserved used for and why do I need it if I already have a Recovery partition setup By Acer Aspire 7741Z? ...
Backup and Restore
Create the Windows 7 System Reserved partition
Here are three options for the creation / use of the Windows 7 System Reserved partition. System Reserved : Create Using Disk Management System Reserved : Multi Boot from Logical Partitions System Reserved : Create for Dual Boot
Installation & Setup
I have now created this as an actual tutorial that can be viewed at this link below. --> System Reserved : Create for Dual Boot <-- This method goes with this tutorial at the link below but it was too much for the main body of the tutorial as it made the entire work, as a whole too long and...
Create the Windows 7 System Reserved Partition for use with a Dual Boot This shows how to create the new Windows 7 System Reserved partition for use in a dual boot situation when you want to install a second Operating System to the first position on the Hard Disk Dive so you can remove the older...
Tutorials
create a system reserved partition after install?
I have a bit of a problem. I recently got a new SSD and configured it to make it my boot drive. I kept my old installation on my hdd and also made a new partition on that device to hold all of the program files, data, etc. Whenever I was finished installing all the programs that I had on my old...
General Discussion
