Windows 7: System Reserved : Create Using Disk Management
12 Mar 2011   #30
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
1) Do you have the SP 1 installed?
2) Did you create the disk before you installed the SP 1 to the system?
12 Mar 2011   #31
RJ12
Quote   Quote: Originally Posted by Bare Foot Kid View Post
No
No
(answered above)
12 Mar 2011   #32
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
OK here we go.
First use Windows 7 disk management to shrink the 1.46GB partition to as small as it will go but not below the suggested 200MB boot partition you're trying to create.
Study this tutorial at the link below before you start so you will know how to proceed if you develop boot issues.
Startup Repair - Run 3 Separate Times
You would have to boot to diskpart to mark the Windows 7 partition as Active as outlined in Option Two #1 and do the 3 separate startup repairs to create the boot files to the Windows 7 partition, but don't do that if it is not necessary as it's a step that's not needed unless you have boot issues.
12 Mar 2011   #33
RJ12
OK here we go.
Ok, Thanks!
Edit: Just realised, the partition is already marked active
12 Mar 2011   #34
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
Quote   Quote: Originally Posted by RJ12 View Post
Ok, Thanks!
Then post back here and we'll pick it up again!
12 Mar 2011   #35
RJ12
So its ok to resize it even though it's already marked Active?
12 Mar 2011   #36
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
Yes, just do the shrink using disk management and nothing else.
12 Mar 2011   #37
NoN
OK here we go.
I'm glad hearing you saying that...
i was studying that tutorial "startup repair - run 3 separate times" two days ago...and was wondering myself if it was really necessary to do it.
I've done just by curiosity a 3 startup repair (rebooting each time between repair), two days ago without marking the partition active as tutorial said.
Of course it did not find any troubleshoot during the 3 repairs. Was wondering the impact of such manner.
You made it clear to me, today...!
12 Mar 2011   #38
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
Quote   Quote: Originally Posted by NoN View Post
Glad I could help mate and thanks for the input!
26 Jun 2011   #39
maiki
Thank you for the tutorial.
I am not sure that I understand the two options.
Is the first option self-sufficient in itself?
Even though one does not put any files into that system-reserved partition? Are all the files necessary for the repair options on the boot drive, and the sr partition is only necessary to access it?
Thank you.
Changing System Reserved information in Disk Management
Hello all. I have recently done a repair install to fix an issue with Windows Media Player. But before that, I had changed the C drive or partition to active, and have read just now that the system reserved part should be marked active. Can I switch it back to active without anything bad...
General Discussion
Disk management - system reserved
Win 7 Home Premium 64-bit SP1. What is system reserved used for and why do I need it if I already have a Recovery partition setup By Acer Aspire 7741Z? ...
Backup and Restore
Create the Windows 7 System Reserved partition
Here are three options for the creation / use of the Windows 7 System Reserved partition. System Reserved : Create Using Disk Management System Reserved : Multi Boot from Logical Partitions System Reserved : Create for Dual Boot
Installation & Setup
I have now created this as an actual tutorial that can be viewed at this link below. --> System Reserved : Create for Dual Boot <-- This method goes with this tutorial at the link below but it was too much for the main body of the tutorial as it made the entire work, as a whole too long and...
Create the Windows 7 System Reserved Partition for use with a Dual Boot This shows how to create the new Windows 7 System Reserved partition for use in a dual boot situation when you want to install a second Operating System to the first position on the Hard Disk Dive so you can remove the older...
Tutorials
create a system reserved partition after install?
I have a bit of a problem. I recently got a new SSD and configured it to make it my boot drive. I kept my old installation on my hdd and also made a new partition on that device to hold all of the program files, data, etc. Whenever I was finished installing all the programs that I had on my old...
General Discussion
