Windows 7: System Reserved : Create Using Disk Management
26 Jun 2011   #40
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
Hello maiki.
After the System Reserved is created, you would need to mark that the Active partition and run the 3 separate startup repairs to the new SysResv partition, to (re)create the "System" system volume boot files it that location; then that will place the "Repair my Computer" link on the advanced boot options boot menu.
There is additional information contained in this tutorial at the link below and be sure to post back with any further questions you may have and to keep us informed.
Startup Repair - Run 3 Separate Times
26 Jun 2011   #41
maiki
Thanks for the explanation.
My situation-I have dual-boot XP and 7 set up. It used to work-- startup repair, without optical disc.
However later, after the Win7 install became corrupted, and I had to do a repair install, it doesn't work. I still see the option under the advanced F8 boot options, but if I choose it, it tells me to insert my Win7 disc and reboot.
I have the Win7 DVD, and can do startup repair from there. However, the computer in question is a netbook, without built-in CD-DVD drive. If I am anywhere besides home, I don't have the USB optical drive, and disc with me. So I would like to get that capability back.
Now, if I just mark the newly created System Reserved partition as Active, and reboot, it won't boot, correct, as there is no OS there?
I don't know what you mean by:
Could you please explain? I can run startup repair (from the DVD) but how do I run it to the system reserved partition?
Thank you.
Quote   Quote: Originally Posted by Bare Foot Kid View Post
Hello maiki.
26 Jun 2011   #42
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
You need to mark the SysResv as the Active partition and run the 3 separate startup repairs to create the SysResv partition as the "System" partition, where the boot files are stored.
Please post a snip on the maximized Windows disk management so I can see it.
In the Windows start menu right click computer and click manage, in the left pane of the "Computer Management" window that opens click disk management and post a maximized snip of that.
How to Upload and Post a Screenshot and File in Seven Forums
06 Jul 2011   #43
PunchsucKr
Windows 7 Ultimate x86
Excellent tutorial.
I have a doubt though, after the system reserved partition is created, will windows move the boot files or whatever is supposed to be on that partition all by itself after this partition is created and add the F8 winre option without giving it any additional commands to do so?
EDIT: also will it be fine to create just the 100mb partition cause i never intend to dual boot.
06 Jul 2011   #44
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
Hello mate, thanks!
You can create it a 100MB if you like; after it's created you will have to mark it Active and run the 3 separate startup repairs with restarts, to (re)create the "System" boot files to the new SysResv, have a look at this tutorial at the link below and be sure to post back with any further questions you may have and to keep me informed.
07 Jul 2011   #45
PunchsucKr
Alright thanks BareFootKid that certainly clarified things.
However i guess i won't be able to easily extend my c: after this partition has been created to its right, i'll be doing this after getting another hdd and extending c to the max win7 should ever need as presently its just 40gb and quickly running out.
07 Jul 2011   #46
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
Quote   Quote: Originally Posted by PunchsucKr View Post
If you can post a snip of Windows disk management and clarify what you are referring to I may be more help to you; have a look at the info below.
Note   Note
07 Jul 2011   #47
PunchsucKr
What i'm sayin is that presently i dont have a lot of free space on my hdd, and even lesser on the system partition c:, so i'll first have to get an additional hdd, move my data to that one, then carry out these and other partition modifications.
furthermore since the system reserved partition will be generated to the right side of c drive, i guess i wont be easily able to extend c drive in future, not with native disk management anyways. so i will first extend my c: to like a 100 gb then create the system reserved, which can only happen after i get another hdd.
07 Jul 2011   #48
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
Then create it on the left side of the C: partition, have a look at Step One of this tutorial.
System Reserved : Create for Dual Boot
07 Jul 2011   #49
PunchsucKr
Thats certainly helpful thanks. The link to partition wizrd on the tutorial is giving a 404 not found error, is this the same thing Free Partition Magic alternative. Free Partition Manager Software for Windows 7/VISTA/XP/2000 and Windows Server 2003/2008/2000.??
EDIT: Furthermore is it necessary to use their bootable disk or can i just use the installer?
Changing System Reserved information in Disk Management
Hello all. I have recently done a repair install to fix an issue with Windows Media Player. But before that, I had changed the C drive or partition to active, and have read just now that the system reserved part should be marked active. Can I switch it back to active without anything bad...
General Discussion
Disk management - system reserved
Win 7 Home Premium 64-bit SP1. What is system reserved used for and why do I need it if I already have a Recovery partition setup By Acer Aspire 7741Z? ...
Backup and Restore
Create the Windows 7 System Reserved partition
Here are three options for the creation / use of the Windows 7 System Reserved partition. System Reserved : Create Using Disk Management System Reserved : Multi Boot from Logical Partitions System Reserved : Create for Dual Boot
Installation & Setup
I have now created this as an actual tutorial that can be viewed at this link below. --> System Reserved : Create for Dual Boot <-- This method goes with this tutorial at the link below but it was too much for the main body of the tutorial as it made the entire work, as a whole too long and...
Create the Windows 7 System Reserved Partition for use with a Dual Boot This shows how to create the new Windows 7 System Reserved partition for use in a dual boot situation when you want to install a second Operating System to the first position on the Hard Disk Dive so you can remove the older...
Tutorials
create a system reserved partition after install?
I have a bit of a problem. I recently got a new SSD and configured it to make it my boot drive. I kept my old installation on my hdd and also made a new partition on that device to hold all of the program files, data, etc. Whenever I was finished installing all the programs that I had on my old...
General Discussion
