#50
It would be very wise to use the boot disk, it's a lot more reliable than the installed version.
Here you go, thanks for the heads-up about the link, I have fixed that.
First download the Partition Wizard Bootable Disk (PWBD) ISO file to the desktop, be sure to get the PWBD and not the installed version; scroll down to see the download link for the bootable CD ISO file at this link below.
Then use ImgBurn to burn the ISO to a CD, at no greater than 4x speed with a verify; it was designed for use and works best from a CD rather that a then boot the created CD to make the changes.
