#220
Use with ZTreeWin
Hi gurus all,
I have applied the method in the tutorial, which is excellent work, thank you.
However on one program, ZTreeWin, there is a minor irritation.
I have pinned the shortcut to the task bar so ZTreeWin opens with one click.
But its window is not active - I have to click in the window before I can use it.
I really want to click once and immediately be able to key in any command to ZTreeWin.
Is there any way to retain the focus on the opened ZTreeWin program?
Many thanks, marcvarc.
