#410
What do you mean by having it run from a context menu ?Hi Brink ...
First, thanks for the great tutorial.
I just purchased a new PC with Win 7 Home Premium and found the UAC process a bit tedious for programs I run frequently, for example, Search Everything. I followed your tutorial and it's working fine.
However, more often than not, I want to run it from a context menu. Way back in post #'s 10 and 11, I *think* Lebon14 also wanted to do this and you responded with a registry add like this:
[HKEY_CLASSES_ROOT\*\shell\Every Search]
[HKEY_CLASSES_ROOT\*\shell\Every Search\command]
@=”\”C:\\Users\\Ed\\Desktop\\Every Search.lnk\” \”%1\”"
but obviously with the program (Notepad++) he was concerned with.
My question - if I stuck those three lines in a text editor such as Notepad and changed the file extension to .reg, is that sufficient to correctly update the registry?
Thanks for your help
EdP
