How to Create an Elevated Program Shortcut without a UAC Prompt in Windows
This will show you how to create an elevated "Run as administrator" shortcut of any installed program using Task Scheduler so that it will not give you a UAC prompt for permission when you start it while still having UAC turned on in Vista, Windows 7, and Windows 8.
In the tutorial, you will first create a new task, then a new shortcut to run the task. Afterwards, how to change the icon of the shortcut.
Special thanks to OEM for pointing this out, and the previous Vista version by DMEX.
   Warning
  • This shortcut and task can only be created and work while logged in as an administrator account.
  • This shortcut will not work in a standard user account.
Here's How:
1. Press the Windows + R keys to open the Run dialog, type taskschd.msc, and press Enter.
NOTE: This will open Task Scheduler. This file is located at:
C:\Windows\system32\taskschd.msc.
2. While having Task Scheduler Library selected in the left pane, click/tap on Create task in the far right pane. (see screenshot below)
3. Under the General tab, type in the "Name" of the program you want to create this shortcut for. (see screenshot below)
NOTE: This will be the name of the task. As an example, I will use CCleaner for that program. Make note of this name, you will need it later in step 12 and 14 below.
4. Check the Run with highest privileges box. (See screenshot below)
5. Click/tap on the Configure for drop down box to open it, and select Windows® 7, Windows Server™ 2008 R2 or the Windows you are currently in. (see screenshot above and below)
NOTE: This is like compatibility mode. If the program does not support running in Windows 7 normally, then you can select the OS that is does support running in instead to have it run in compatibility mode as if it was running in that OS instead of Windows 7.
6. Click/tap on the Actions tab, then on the New button. (see screenshot below)
7. In the Program/script: box in the Actions tab, copy and paste the path below. (see screenshot below step 9)
NOTE: Thank you to chillz for the updated steps 7 and 8.
%windir%\System32\cmd.exe
8. In the Add arguments (optional): box in the Actions tab, type in the argument below. (see screenshot below step 9)
NOTE: Substitute Task Name in the argument below with the name you entered in step 3 (ex: CCleaner) within quotes, and substitute Full Path of Program in the argument below with the actual full path of the program's .exe file within quote.
/c start "Task Name" "Full Path of Program"
For example:
/c start "CCleaner" "C:\Program Files\CCleaner\CCleaner64.exe"
9. Click/tap on OK. (see screenshot below)
10. Click/tap on the Conditions tab, and uncheck the Stop if the computer switches to battery power box first, then uncheck the Start the task only if the computer is on AC power box. (see screenshots below)
NOTE: This step is mostly for laptops, so that you will be able to run the program when the laptop is running on battery power.
11. Click/tap on OK. (See screenshots above)
12. You will now see your new task created with the name (ex: CCleaner) you gave it in step 3. Close Task Scheduler. (see screenshot below)
13. Right click or press and hold on an empty area of your desktop, then click/tap on New and Shortcut.
14. Type in the target below for the location field, then click/tap on the Next button. (see screenshot below)
NOTE: Subsitute task-name in the target with the name (ex: CCleaner) within quotes that you used in step 3.
schtasks /run /tn "task-name"
For example: For my task name CCleaner I used from step 3, I would type:
schtasks /run /tn "CCleaner"
15. Type in a name you want for the shortcut (ex: CCleaner), then click/tap on the Finish button. (see screenshot below)
16. Right click on the new shortcut (ex: CCleaner) on the desktop, then click/tap on Properties.
17. Click/tap on the Shortcut tab, and on the Change Icon button. (see screenshot below)
18. Click/tap on OK. (see screenshot below)
19. Click/tap on the Browse button. (see screenshot below)
20. Navigate to the .exe file of the program that you have created this shortcut with, select it, and click/tap on Open. (see screenshot below)
NOTE: If you have a icon of your own that you would prefer to use instead, then navigate to where you have that icon saved at instead.
21. Select the icon you want for the shortcut, then click/tap on OK. (see screenshot below)
22. Click/tap on OK. (see screenshot below)
23. You can now use this elevated shortcut to run at startup in your "Startup" folder, run at startup as a task, Pin to Start Menu, Pin to Taskbar, assign a keyboard shortcut, or move to where you like for easy use.
24. When you run this new elevated shortcut, you will now no longer have to click/tap on YES to approve the UAC prompt to allow the program run as administrator.
   Tip
To Undo and Remove this Task:
  • While having Task Scheduler Library selected in the left pane, right click on the task in the right pane that you created in step 12, then click on Delete and Yes to approve.
  • Delete the shortcut.
As always, very well done Shawn, tutorial is easy to read and understand.
This makes working with programs requiring a uac prompt that you trust a pleasure to run again, while keeping the security offered by the uac on and intact. ;)
Note: Also works on Vista.
Thanks Shawn for this and All your contributions here on the greatest forum for Windows Se7en.
Added:
Have the program load on start minimized:
To do this, you'll need to create a very simple .bat file. To start, Open your favorite text editor like notepad. Enter the following:
@echo off
start /MIN "" "C:\Program Files\CCleaner\CCleaner.exe"
The above is an example for cCleaner. For other programs, Simply enter the path to your program in quotes. Notice the 2 quotation marks placed together, anything you wish can be entered between them, but they must be there. See example:
@echo off
start /MIN "[B][I]cCleaner[/I][/B]" "C:\Program Files\CCleaner\CCleaner.exe"
Now you need to save this as a bat file. You do this by clicking file, then "save as" and in the save as box, there is a drop down for "save as type", choose "ALL TYPES" and name it something like "cCleaner.bat" to a location like "C:\MyBatFiles". You need to save the file with the ".bat" at the end. Thats how your basic notepad becomes a bat file. I recommend saving it to the c:\ root because it may need access to the file before you log in and if your not logged in yet the program might not load. So create a folder directly in C:\ drive and create a folder like the above example "MyBatFiles".
Example of "save as" above path:
C:\MyBatFiles\cCleaner.bat
Next you need to change the task scheduler for the program, so open it by typing task scheduler in start search and select it. If your tasks are not shown, Click on the Library folder near the upper left, then double click on the task you want to have open minimized on start up. Click on the "Actions" tab and highlight the current path and click "edit". In the opened edit window, you need to now browse to the newly created .bat file you just created. Once done click "OK".
Next, click on the "Triggers" tab. Click new and choose the option that best works for you from the drop down "Begin the task". For example "At startup". Click OK, then click OK to close the task editor. Thats it, your UAC program will not require your input, and will start automatically minimized for you.
   Tip
For testing, in the triggers tab, "Begin the task" drop down, choose "On Workstation Lock". This way to test it, you don't have to restart the PC, just select "Lock" from the start menu. Once you log back on, you should see the program loaded and minimized. If so, you then can go back and choose at "At startup" in the task scheduler "triggers" tab, begin the task drop down.
Enjoy your program loading on startup, minimized, without UAC prompt input!
OS3.5celerymemory never forgetsOB
POS
OS3.5
celery
Good Question ...Unknown
OB
OB
HUGE
168000000x105000000
full
OEM 65watt
N/A
OB
OB
mouse
1 Trillion MBps
Still An Awesome Forum!
You're welcome OEM. :)
Thank you,
It doesn't works for me! I tryed everything but it was worthless.
Im running windows 7 RC.:confused:
Windows 7 Ultimate x86 build 7100CPU INTEL Core i7 920 BOX, s. 1366, 2.66GHz, ...RAM PC-10600, 6 GB, CORSAIR TR3X6G1333C9, DDR...VGA PCI-E XFX GeForce GTX 295, 1792 MB DDR3, ...
CPU INTEL Core i7 920 BOX, s. 1366, 2.66GHz, 8MB c., FSB 133
MBO ASUS RAMPAGE II EXTREME, Intel X58/ICH10R, DDR3, zvuk, 2
RAM PC-10600, 6 GB, CORSAIR TR3X6G1333C9, DDR3 1333MHz, KIT
VGA PCI-E XFX GeForce GTX 295, 1792 MB DDR3, DualDVI, HDMI,
HDD 750.0 GB WESTERN DIGITAL, Caviar Green7500AACS, SATA, 16MB cache, 7200
Hello Axematic,
What program are you trying this with, and did you select the correct .exe file?
Hello Brink!
Im trying this for CCleaner. I browsed to .exe file and added a task to task scheduler. Even i am able to start it directly from scheduler(right click and run) but shortcut on my desktop doesn't starts a CCleaner. Maybe im doing something wrong?
I used this as shortcut target: schtasks /run /tn CCleaner
Are you doing this in an administrator account?
You might delete this to undo it, then start over. Double check through each step carefully. You may have just made a simple mistake somewhere. :)
Please let us know how it went.
Hello Axematic,
I'm just checking in to see if you were able to get to work for you. :)
Success Brink!!!
It works perfectly now! But i didn't find my mistake. I tryed all steps again 100% the same as above, and it worked. Cmd pop-ups and scheduled program runs.
And yes, im doing this as administrator!
And finally thanks!:) i hate UAC sometimes, but i dnt want to turn it off!
Sorry if my english was bad, it's foreign language for me.:D
Axematic, I'm happy to hear that you got it working. Thank you for posting back. :)
Hi there Brink.
I wanted to know if it's possible to do this trick for a software that I use... from the context menu like Notepad ++. I hate the bullcrap that it can't write to my Vista partition and I want to use this workaround for it. Is there a way?
Windows 10 Professional 64-bitRyzen 9 5900XG.Skill 3600Mhz CL16 16GB × 4EVGA GeForce RTX 3070 Ti FTW3 Ultra Gaming
Custom build
Ryzen 9 5900X
Gigabyte X570 Aorus Master
On-board
Dell Alienware AW3418DW
3440x1440
1×Sabrent Rocket 4 Plus 2TB nvme SSD (System, internal)
2x4TB Western Digital Blue (Internal)
1x4TB HDST 7200RPM (Internal)
Seasonic Focus Plus 850W Platinum
Corsair 680X
Stock fans + 3× Corsair QL120, Corsair H100i Platinum
Logitech K350
Logitech M510
120Mbits dl - 20Mbits up
ESET NOD32 Antivirus
Firefox (latest version)
Headphones : Audio-Technica ATH-M50x
Scanner : Canon Canoscan LiDE 220 + Plustek OptiBook 4800
Hello Sébastien,
Sure. You would just create the shortcut in this tutorial, then add this to the registry:
[HKEY_CLASSES_ROOT\*\shell\Notepad++]
[HKEY_CLASSES_ROOT\*\shell\Notepad++\command]
@=”\”C:\\Program Files\\Notepad++\\Notepad++.lnk\” \”%1\”"
Substitute C:\\Program Files\\Notepad++\\Notepad++.lnk\ with the full path that you saved the shortcut at instead though, but leave the same amount of slashes in it.
This is great for the programs used daily.
Easy to follow and worked the first time.
Windows 7 Ult x64 - SP1/ Windows 8 Pro x64Intel Core i5-3570K 4.6GHz8GB (2X4GB) DDR3 1600 Corsair Vengeance CL8 1.5vSapphire HD 7770 Vapor-X OC 1GB DDR5
76~2.0
Gigabyte GA-Z77X UD3H, f18
Onboard VIA VT2021
22" LCD Dell
Samsung 840Pro 128GB SSD,
Corsair HX650W
Cooler Master Storm Scout
Logitech Wave
CM Sentinel
Dismal
Opera Next
Desktop: eSATA ports,
External WD USB 500GB
You're welcome Dave. :)
This was exactly what I was looking for!
Windows 7 Ultimate x64Q9550 @ 3.8Ghz4GB Muskin4870x2
Q9550 @ 3.8Ghz
ASUS Rampage Formula
4GB Muskin
4870x2
Dell 3007WFP-HC, Dell 2007WFP, Dell 2007WFP
640GB Caviar Black
Corsair 1000HX
ATCS 840
Watercooling
hi,
i do have problems creating a tasks with a "normal" user because of insufficient privileges. when i create the task with an administrator, then the normal user cannot run the task, because he's not allowed to.
jakob
Win7 Home Premium 32
HP NC6400, HP 6710B, HP 6830S
Hello Jacob, and welcome to Seven Forums.
If you mean creating elevated shortcuts for programs, then the only way a non-administrator account can run them is to provide the administrator's password when prompted by UAC. Otherwise a Standard or Guest account will not be able to run anything that requires UAC permission to run as administrator. :(
hi brink,
thank you for your answer.
I tried to create a simple task running notepad.exe with a standard user. This works as long as i do not check "Run with highest privileges". When i check this option a dialog pops up asking for a user and the password. neither the standard nor the administrator user is accepted.
Actually i wanted to run RMClock as a standard user :(
jakob
You may only be able to run in an administrator account. :(
UAC and admin shortcut
Excellent! Friend. I knew there was a way around that nasty UAC prompt. I also knew that I din't know enough to do it.
win 7 X64 Ultimate SP1I3770KG Skill F3-14900CL9-4GBXL x 4NVIDIA GeForce GTX670 + Intel 4000
BGC (Bob's Garage Crew)
I3770K
Asus P8Z77-V Deluxe
Realtek HD 5.1 (MOB)
Asus VW224T (1)
SATA Corsair Force GT 2.5" 180GB (System) Sata 3
OCZ Vertex3 120GB
OCZ Vertex 2 120GB 2.5" SATA II
ST31000524AS 1000.2GB
WD15EARS (External)
CoolerMaster 1000 Watt
CoolerMaster HAF X
CPU -- CoolerMaster 520N
MS Wireless 3000 V2
MS Wireless 3000 V2
Cable
Norton Internet Security
IE9
AMI Bios 1805
OC'd 3%
