Windows 7: Wireless Network - Remove
How to Remove a Wireless Network in Windows 7
Published by Orbital Shark
26 Oct 2010
information   Information
This tutorial can be used to show you how to remove a wireless network from within the Network and Sharing Center.
This can prove handy if you are having internet connectivity issues whereby you can connect to the network but it has limited access.
Here's How:
1, Right-click the network icon on the taskbar.
Note   Note
You can also access it through Control panel 'Network and Internet' followed by 'Network and Sharing center'
2, Once open, click 'Manage Advanced Networks' in the left hand panel
3, Left-click the wireless network you wish to remove, then click 'Remove' from the panel above
Note   Note
You can also right-click the network and select remove from the context menu
4, Confirm deletion by clicking 'Yes' on the confirmation box
20 Nov 2010   #1
brianzion
nice tutorial
Computer no longer has a wireless driver/Can't detect wireless network
I've had wireless on this pc before. A while back, we had a tech come out from out internet provider to fix a few things, and we told him we already have a few other devices on our wireless network, so it may be a better idea to connect through an ether-net cord to our main pc for a more secure...
Drivers
Wireless network disconnects, then fails to see the wireless network
Every so often, my WiFi on my PC will just stop working. It will disconnect from my wireless network, and then when I try to manually connect, it's not listed. Sometimes a restart works, sometimes it doesn't. This last time I had to restart twice. I know the WiFi router is not having problems,...
Network & Sharing
How do I remove network path? (network file and folder settings)
After reinstalling OS, I was fiddling around to change the name of the user folder until I accidentally added network path from folder sharing option as you can see from the screenshot below: http://i.imgur.com/JlJI78c.png Is there a way to remove such path or make that space "not shared" like...
Network & Sharing
Wireless Network Adapter vs. Wireless Router Module
I looked in Device Manager and don't see a wireless network adapter but under Network Infrastructue Devices I see "Microsoft Wireless Router Module". Are these the same thing? Thanks for help!
Network & Sharing
Unable to remove old wireless network
Hi I've just changed providers and now have a new router. It's still appearing in "manage wireless networks". I've removed this network so that there is only one listed however when I log off & back on again, it re-appears. My account is an administrator account so I should be able to do this. ...
Network & Sharing
How do I remove annoying suffix number from wireless network name ?
Hi I've just upgraded my ADSL router, and renamed the network SSID (in the router) to my preferred name. Windows detected it fine, but when I hover over the wireless icon on taskbar it says: "...... 2" (where ...... is the name of my network) In the Network and Sharing center settings...
Network & Sharing
