Windows XP Mode - Enable Built-in Administrator Account
    How to Enable the Built-in Administrator Account in Windows XP Mode
    When you install and launch Windows XP Mode for the first time it has following account related defaults:
    • Default user: XPMUser
    • Integration Features enabled
    • Built-In Administrator account disabled
    • All user accounts must use / have password
    When Integration Features are enabled on any Microsoft Virtual PC virtual machine you can only use and login to accounts with a password. Only way to use accounts with no password is to disable Integration Features. This is not recommendable as so much of Virtual PC virtual machine's functions need integration to work properly.
    To be able to run programs as Administrator or login to Administrator account you need to enable the account and set a password for it. This tutorial will show you how.
    Notice that this method can also be used on all other Windows XP, Vista and 7 virtual machines running on Microsoft Virtual PC.
    OPTION ONE
    Running a Program as Administrator without Setting a Password
    If you do not want to permanently enable built-in administrator account and set a password for it, this workaround let's you run a program as Administrator.
    1. Disable Virtual PC Integration Features:
    2. Run the application as administrator with a blank password:
    3. Re-enable integration features
    OPTION TWO
    Permanently Enable Built-in Administrator Account in XP Mode
    1. Open Start Menu, right click My Computer and select Manage from context menu:
    2. When in Management Console, goto Computer Management > Local Users and Groups > Users, right click Administrator, select Properties from context menu. Now select General tab and uncheck Account is disabled:
    3. Click OK to save settings
    4. Right click Administrator, select Set password:
    5. Read the warnings, click Proceed if you want to proceed:
    6. Type the new password, confirm it and save it by clicking OK:
    7. Click OK to close the confirmation dialog:
    8. Close management console
    Now you can run programs as administrator even when integration is enabled. You can also login to XP Mode using this account.
    Kari
  1. Posts : 1,800
    Windows 7 Pro x64 SP1
    I have successfully used the XP Powertoys and set up the XP mode to automatically login as administrator.
    rich
